UP Studio
UP Studio
Powerful Software to Simplify your Workflow.
Start a print job with 3 clicks
UP Studio’s rich feature set and ease-of-use have gained a loyal following over the years. Many customers purchase Tiertime printers specifically because they love the software.
With the support of latest Task format (.TSK), users can set print parameters according parts property and print parts with variable parameters in a single printing process. This give user unmatched versatility on planing production.
Print parts with different parameters in a single printing process
  • Complete set of layout and adjustment tools
  • Simple to use,plug and play with optimized print parameters
  • Support file formats: .up3, .ups, .stl, .obj, .3mf, .ply, .off, .3ds, .gcode*
Automatic Smart Support Generation.
Print Preview and Manual Support Editing,Real-time preview of result by adjusting parameters on support editor.
Comfortable support removal experience.
Detailed tool path preview
Detailed tool path preview and pause print at specific layer.Save current project into .TSK file format for later use of sharing.
Time & Material estimates
Comphresive Print Preview with material usage and time estimates, allows you to cost prototypes before printing.
Switch on or off or make it invisible
Trace support intuitively by hovering on the target support, the corresponding support will be selection in the support editor.
Material Profile Manager
Full set of parameters for optimizing print quality with 3rdparty materials.
Copy/Modify/Import/Export of material profiles.
Set password for your profiles to prevent unauthorized modification.
9-point Martix Leveling
UP Studios unique Matrix Leveling, even the platform is tilted and uneven, still ensure object is printed on flat surface of raft to preserve dimensional accuracy and a firm first layer adhesion.
Grid Based Leveling
Mesh Leveling
9-Point Matrix Leveling
Dimensional Calibration
squareness
The application inherits the capabilities of UP Studio to import 2D images and convert them into 3D models. Photos, logos, slogans, anything you want.
Image to lithopane
Convert 2D images into 3D images
Preset parametric object
Tiertime Print Queue and Continous Printing
In-App Support Ticket Submission
If you have any problems with the printer, you can send us messages right inside UP Studio. Our support ticket system will able to obtain machine info from UP Studio to help support agents to diagnose the problems.
UP Studio
