Uncompromising Performance
Drawing upon Tiertime’s industrial roots, the UP BOX+ is packed with luxuries not typically found in its price range. Its passively-heated enclosure can produce large ABS prints with minimal chance of warping. Its software and auto-leveling ensure you spend your time printing instead of adjusting your printer. Compare its build volume, full enclosure and air filtration to similarly priced machines and your choice will be clear.
One-Year Manufacturer’s Warranty
Rest easy knowing your investment is safe. Tiertime warranties all UP printers against manufacturing defects for a period of one year from the date of purchase.
Included Accessories
- 1 0.5 kg spool of UP Fila ABS
- 1 Bed scraper
- 1 Filament cutter
- 1 Pair of heat-resistant gloves
- 2 UP Perf Boards, 2 UP Flex Boards
- 1 Micro SD card and reader
- 2 0.4 mm nozzles
- 1 Nozzle wrench
- 1 Spool cover for 1 kg spools
- 1 Spool rack for 1 kg spools
- 2 Binder clips
- 1 Calibration card
