UP mini 3
The UP mini series are built for everybody with easy-to-use and safety in mind. The new UP mini 3, with a new look, has made crucial upgrades with bigger build plate, true auto calibration and filament runout protection.
A perfect printer for Schools and Families
Easy to use with a new adequate size for printing in Schools, the UP mini 3 meets the requirements in schools. With a bigger build plate and easy-to-use software, the printer has all the features needed.
Safety Features for classrooms and offices
In addition, the UP mini 3 has a safety feature to pause printing when the door is opened, and also pause printing when the filament runs out.
Toxic odor free with
Air Filter
The embedded air filter, with HEPA and Activated Carbon filtration system, removes toxic air that circulates inside the printer while printing plastic filament. Effectively reduce toxic elements, known to be the triggers of asthma and other pulmonary disorders.
True Auto Calibration
based on Load Balancing
The new bed leveling mechanism is based on the concept of load balancing. The calibration does not need human intervention, which is easy to operate and accurate as well.
Specifications
Calibration and leveling True Touch 2.0, Automatic
Layer Resolution 0.1 / 0.15 / 0.2 /0.25 / 0.3 / 0.35 mm
Buildplate Surface UP Glass Perf or UP Glass Flex, Heated
Dual Filtration System HEPA and Activited Carbon Filters
Print Resume On Power interrupt Yes
Pause to Change Filament Type Yes
Out of Filament Detection Yes
Filament UP Fila ABS,ABS+,PLA,TPU and 3rd Parties
Filament Diameter 1.75mm
Filament Spool Compatibility 500g,1kg or 2kg
Operating Sound 47 db
Software
Special Features
- Preview Support Structures
- Tiertime Print Queue
- Power Loss Recovery
- Door Open Pause Protection
