UP mini 2 ES
3D Printer Accessibility Redefined
$699
What's new in UP mini 2 ES?
The UP mini 2 ES is a more advanced mini 2 with improved hardware and software.
It inherited its predecessor’s full enclosure with built-in HEPA and activated carbon filter.
Tiertime Print Queue
Coming with the feature like Tiertime print queue,
it fits more in the office,
classroom and home environments.
Touchscreen Control
Upgradeable System
Editable Printer IP Address
Print Job Storage
More Connectivity
Ethernet Socket
Extra USB Port
4.3 Inch LCD Touchscreen
Upgraded
An updated control screen verses the original mini 2, it has more features and functionality, plus the ability to be enhanced via future upgrade-able touchscreen system.
3D Printing Workflow
Enhanced
An Ethernet socket allows you to connect your printer to a wired Local Area Network for maximum security.
Tiertime’s new Print Queue allows more than one user to send print jobs to the printer simultaneously.
Files to be printed appear in the queue’s print list on a first come, first serve basis.
Allows multiple users to send print jobs from different devices to the same printer via USB/ Wi-Fi/ LAN.
Version 1
HEPA and Activated Carbon Filter
3D printing certain materials such as ABS can generate potentially harmful
UFP and VOC emissions. The HEPA and Activated Carbon filter effectively
reduce these toxic elements, known to be triggers for those suffering from
asthma and other pulmonary disorders.
Specifications and Warranty
Printer
Printing Technology  MEM  (Melted Extrusion Modelling)
Extruder Single
Nozzle Diameter 0.4mm
Extruder Maximum Temperature 299℃
Extruder Maximum Travel Speed 200 mm/sec
XYZ Accuracy 5, 5, 5 micron
Connectivity USB Cable, Wi-Fi, LAN and USB Drive
Display 4.3″ Full Colored LCD Touchscreen
Build Volume 120 ×120 ×120 mm (7″ x 9″ x7.8″)(XYZ)
Printed Object Accuracy ±0.1mm/100mm
Layer Resolution 0.15/0.2/0.25/0.3/0.35mm
Build Plate Maximum Temperature 70℃
Calibration and Levelling Auto Nozzle Detect
Build Plate Surface Perf or Flex, Heated
Pause to Change Filament Type Yes
Filament UP Fila ABS,  ABS+,  PLA,  TPU and more
Filament Diameter 1.75mm
Filament Spool Compatibility 500g
Compatible with 3rd Party Filament Yes
Software
Software UP Studio Version 2.5 or above
Supported OS Windows 7 (SP1) or higher (32 bit and 64 bit) Mac OS 10.10
Hardware Requirements OpenGL 2.0 At least 4GB of RAM
Importable File Formats .up3, .ups, .tsk, .stl, .obj, .3mf, .ply, .off, .3ds
Preview Support Structures Yes
Editable Support Structures Yes
Physical Dimensions
Machine Dimensions 255 x 365 x 385 mm (19.3″ x 20.5″ x 18.1″)
Net Weight 52kg
Shipping Box Dimensions –
Shipping Box Weight 7.5kg
Power Requirements
Power Input 110-240VAC,50-60Hz,90W
