Tips and Tricks
Print from a USB Stick
New Feature Announcement In the latest Touch Screen Program (V2.5034), we released the new feature “Print from a USB Stick”. User can save a Tiertime TSK file on a USB stick drive, take the drive to any compatible Tiertime 3D printer, and print the TSK file directly without the need of using UP Studio on [...]
Material Profile Manager
Interface Introduction The following window is the main interface for the Material Profile Manager. The interface includes several function areas which we will discuss one by one in details: Material Profile List Material Actions Printer Models Printer Settings Material Parameter Settings Print Parameter Settings
Comparison for Three Different Extruders
PLA Extruder Enhanced Cooling. Best for low temperature filaments, e. g. PLA. ABS Extruder General Extruder with Fan Duct Switch. Capable of printing high temperature filaments, e. g. ABS TPU Extruder Better Feeding Less Jamming. Best to work with flexible materials, e. g. TPU Size of Fan Block A bigger fan block provides extra air [...]
Tiertime Print Queue
Tiertime Print Queue allows multiple users on the same Local Area Network simultaneously send print jobs from different devices to a shared printer via USB/Wi-Fi/Ethernet. You and your colleagues could send your model data using just one printer without unnecessary time wasted waiting for other people’s print jobs to finish. Print jobs in the Print [...]
Introducing the Tiertime Task
Purpose: Tiertime Task is a type of sliced model file specifically created for Tiertime 3D Printers. It can be used as a data input source sent to the compatible Tiertime 3D Printers to print without going through the slicing process. Data composition: Tiertime Task file consists of three sets of information, the Print Profile, the [...]
9-Point Calibration Method
Nine-point calibration – commonly known as software-assisted manual calibration – aims to aid you in calibrating the printer for optimal performance through software adjustment. The goal is to produce the best possible print quality and allow for easy removal of support and raft structures. Of the three possible calibration methods, manual calibration provides the most [...]
Model Calibration – XYZ Axial
XYZ Axial Calibration is used to improve dimensional accuracy for a specific model. When a printed object is found to be deviating from its theoretical dimensions, we can use this method to correct it and achieve better precision. You can check your model’s dimensions inside UP Studio by left clicking on the model. Let’s say […]
Model Calibration – Vertical Calibration
In our latest version of UP Studio, we brought back one of its most wanted features, Vertical Calibration. Its main purpose is to ensure all three axes are perpendicular to each other in order to guarantee consistent, high-quality prints. UP Studio achieves vertical calibration by printing a special STL model, VC.stl. (note: the file name […]
