leaking nozzle
arbus
leaking nozzle
Post by arbus » Mon May 16, 2016 2:22 am
hi,
I have a new, secondhand up mini. Working great, except for a leaking nozzle. It is leaking from the top of the nozzle near the heater.
I have taken it apart, cleaned it.
Put it back together. Tightened it when hot.
But still leaking quite bad.
Any tricks to tightening the nozzle and not getting a leak?
3DSTB
Re: leaking nozzle
Post by 3DSTB » Mon May 16, 2016 8:09 pm
i had the same problem. I glowed the nozzle and also the part of the Heater. the contact surfaces must be clean. After that it schould be possible the toghten the nozzle right.
Tiertime-Jason
Re: leaking nozzle
Post by Tiertime-Jason » Tue May 17, 2016 12:27 am
wrap the thread with this, put back the nozzle while cool, heat up, tighten.
Do not let it get in the way of the channel.
arbus
Re: leaking nozzle
Post by arbus » Mon May 30, 2016 12:00 pm
Thanks!
Yep plumbers tape fixed it.. But had to use a lot! maybe need to replace the nozzle?
Tiertime-Jason
Re: leaking nozzle
Post by Tiertime-Jason » Tue May 31, 2016 1:17 am
You have to find out which part is the problem, the heater module or the nozzle or both.
