PLA Sticked to print bed
nicosalto
Post by nicosalto » Sat Apr 29, 2017 8:57 am
Hi!
i started printing an object and the pla filament ran out at that time.
Now i have a thin layer of PLA sticked to to the print bed, and impossible to remove! I tried with a metal spatula but couldn't remove any of it ... :cry:
Does anyone have any tips on how to remove safely the plastic sticked to the bed?
vale_sarbu
Re: PLA Sticked to print bed
Post by vale_sarbu » Tue May 02, 2017 9:24 am
Poke the holes on the bottom. Why is there a huge hole in it?
nicosalto
Post by nicosalto » Tue May 02, 2017 1:45 pm
I found a solution fort this!, i put the plate in the freezer, waited one hour, then i could break down the PLA with a spatula! :D
Post by Owen Sparks aka Marksman » Wed May 03, 2017 6:37 am
(1) Did you not get a scraper supplied with the printer?
(2) Also if that's PLA shouldn't you be printing on the smooth print bed not the perfboard?
nicosalto
Post by nicosalto » Wed Jun 07, 2017 1:36 am
Yes I got the scrapper, it works ok but sometimes it's not enough.
I have a flat bed, but I have the same issue, there is pla stuck on it, impossible to remove...
ksprint
Post by ksprint » Tue Jun 13, 2017 7:13 am
Some PLA dissolve in baking soda solution, not sure if this would work for your case...
nicosalto
Post by nicosalto » Tue Jul 04, 2017 3:54 am
thanks for the tip! i'll try!
