Ramps arduino to UP Mini
Posted: Mon Mar 30, 2015 10:14 pm
by jeeplvr
Most of this has probably been covered but this is how I did it after mu Chitu board fiasco.
Ramps 1.4
Arduino Mega
Manual end stops
Directly wired original heat bed
MK8 extruder and hot end
Modified mag mount extruder carriage
Repositioned end stops with printed mounts
Adjustable Z end stop to compensate for non adjustable heat bed
X end stop
Y end stop
Re: Ramps arduino to UP Mini
Posted: Mon Mar 30, 2015 10:16 pm
by jeeplvr
ATX power supply
Cut opening for USB
Z axis endstop adjustable
Posted: Mon Mar 30, 2015 10:24 pm
by jeeplvr
Posted: Mon Mar 30, 2015 10:31 pm
by jeeplvr
Posted: Mon Mar 30, 2015 10:33 pm
by jeeplvr
Z end stop1.JPG (150.82 KiB) Viewed 10915 times
Z end stop expl.JPG (153.37 KiB) Viewed 10915 times
Z end stop2.JPG (169.28 KiB) Viewed 10915 times
Posted: Mon Mar 30, 2015 10:53 pm
by jeeplvr
Measurement for the Z axis end stop hole
Z axis measurement.jpg (17.3 KiB) Viewed 10913 times
End stop triggers on the Z axis frame
Location of the adjustable end stop for the Z axis
Posted: Mon Jan 25, 2016 3:13 pm
by Tammy
Hello jeeplvr,
i also need to mod my mini with a ramps, as the original controller stopped working.
Can you help me with some information - which firmware do you use, can you provide me your config?
As far as i figured out:
-Steppers are 0.6A
-6.67 steps/mm at 1/1 stepping
Thanks,
Tammy
Posted: Wed Jan 27, 2016 10:12 am
by pp3dp.se
@munex
See the "Custom MCU" thread, might be of some help.
Sorry to hijack your post jeeplvr (Driving a Sahara myself btw;)
//Patrick
