Ribs always get open top?
santel001
Post by santel001 » Wed Aug 02, 2017 12:36 pm
Dear all,
How to have the top of ribs get close?
3D DATA
Re: Ribs always get open top?
Post by DrewPetitclerc » Thu Aug 03, 2017 3:13 am
Try rotating the part in the Z axis from 10 to 45 degrees
Tiertime_Betty
Post by Tiertime_Betty » Thu Aug 03, 2017 5:50 am
you can set contour line width larger.
download/file.php?mode=view&id=2678
santel001
Post by santel001 » Sat Aug 05, 2017 6:16 am
Hi lbbetty
Thanks for your attention, but how to set contour line width?
3DWP
Post by 3DWP » Sat Aug 05, 2017 7:59 am
Link doesn't work, ''There's nothing here''
But you can change the contour width when you click advanced print, the little arrow icon next to the print button I believe.
Tiertime_Betty
Post by Tiertime_Betty » Thu Aug 24, 2017 1:18 am
You can go to "print button(on the left, the second button)"--"advanced print"--"contour width" to change the width of contour line
UP_3DWP wrote:Link doesn't work, ''There's nothing here''
timreger
Post by timreger » Fri Oct 13, 2017 1:09 am
I have the same printing problem - no "cap" on thin walls.
However, there is no contour width setting in advanced print?
Version 2.0.1.3
up studio print.jpg (82.41 KiB) Viewed 6319 times
timreger
Post by timreger » Fri Oct 13, 2017 2:34 am
Found the Advanced Print - but no Contour Width, only Extrusion Width.
Are they the same thing? It was set to 0.5 so will go the maximum and see if that works.
In the middle of a print job on previous post so couldn't access the Print drop down.
up studio print 2.jpg (34.31 KiB) Viewed 6319 times
up studio print 3.jpg (43.19 KiB) Viewed 6319 times
James
Post by James » Wed Nov 22, 2017 7:26 pm
Did that solve the problem?
