[BUG REPORT] UP Studio Crash!! UP Mini
Xonor13
Post by Xonor13 » Mon Jan 16, 2017 11:25 pm
I have not been able to find what is specifically causing this crash for me, but there are other issues occurring at the same time that might be contributing to the crash. When i start up the program, it runs fine and nothing seems wrong until i go into the UP Printing portion. Usually the program doesn't detect my UP Mini 3d Printer and i need to power it down completely and turn it back on using the power switch in the back to have the program detect my printer. Otherwise, if i do anything else while the program doesn't detect my printer it will crash and then i have to redo everything i just did and sometimes it doesn't crash. The same can be said when the program does detect my 3d printer, it will still crash sometimes but not always. It's getting on my nerves and i'm going to downgrade for now until this leaves beta because it doesn't let me print about 90% of the time and just crashes.
Update:
Literally a minute after posting this i have discovered that this crash is not only for UP Studio 1.5.0.3. It turns out this crash is happening on the older version and i would imagine something else is going on here and it is a software issue and maybe even a hardware issue. I have been getting a lot of usb malfunction notifications every now and then when i plug my 3d printer into my computer. My usb cable connector could be faulty and this might be sending a weird signal to the software that it doesn't agree with. I'm not sure if this is the problem but this is my guess. If it is my usb connector then i have no idea where to get a replacement.
Update 2: I have more information regarding this issue after playing around a little more. So there is a mixture of hardware and software issues going on with this crash. I have figured out that when i have my 3d printer connected and not initialized i won't have any issues. However, when i initialize my UP Mini then the program will freeze and become unresponsive. Here is the interesting part, if i don't force the program closed and instead turn the printer off the program will unfreeze and it works perfectly until i reinitialize the printer. The only solution i have for this is to restart my computer every time after a print and for some reason the program and 3d printer decides to work. When the first print finishes the program will freeze if i try to print again. Is there any way to delete my driver and get a new one? I'm thinking i have a corrupt driver or a broken usb connector. Any help is appreciated.
Tiertime_Betty
Re: [BUG REPORT] UP Studio Crash!! UP Mini
Post by Tiertime_Betty » Tue Jan 17, 2017 7:17 am
Thanks so much for your feedback. Could you give us more details like screenshot and log files(you can find this file on "C:\Users\admin\AppData\Roaming\Tiertime\Log"). Thanks again!
Xonor13 wrote:I have not been able to find what is specifically causing this crash for me, but there are other issues occurring at the same time that might be contributing to the crash. When i start up the program, it runs fine and nothing seems wrong until i go into the UP Printing portion. Usually the program doesn't detect my UP Mini 3d Printer and i need to power it down completely and turn it back on using the power switch in the back to have the program detect my printer. Otherwise, if i do anything else while the program doesn't detect my printer it will crash and then i have to redo everything i just did and sometimes it doesn't crash. The same can be said when the program does detect my 3d printer, it will still crash sometimes but not always. It's getting on my nerves and i'm going to downgrade for now until this leaves beta because it doesn't let me print about 90% of the time and just crashes.
Update:
Xonor13
Post by Xonor13 » Mon Feb 06, 2017 8:45 pm
lbbetty wrote:Thanks so much for your feedback. Could you give us more details like screenshot and log files(you can find this file on "C:\Users\admin\AppData\Roaming\Tiertime\Log"). Thanks again!
So i recently had these errors again and now i have the log of the event.
The website doesn't like me attaching the file itself so this is the best i can do.
Code: Select all
[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[ TierTime Begin ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]
SendRequestToServer Begin:https://www.up3d.com/?r=client/bannerapi
SendRequestToServer END OK:https://www.up3d.com/face/index.php?r=getVideo Receive:[{"title":"Withdraw the filament","url":"https:\/\/www.youtube.com\/embed\/aTH97xB-kGQ","url_pic":"https:\/\/www.up3d.com\/face\/model\/w11.png"},{"title":"Extrude the filament","url":"https:\/\/www.youtube.com\/embed\/x1ISld0vrEE","url_pic":"https:\/\/www.up3d.com\/face\/model\/w12.png"},{"title":"Remove model from print bed","url":"https:\/\/www.youtube.com\/embed\/uvRXdyqgQ_A","url_pic":"https:\/\/www.up3d.com\/face\/model\/w13.png"},{"title":"Pause","url":"https:\/\/www.youtube.com\/embed\/izDC4_wRkoQ","url_pic":"https:\/\/www.up3d.com\/face\/model\/w14.png"},{"title":"Remove the support","url":"https:\/\/www.youtube.com\/embed\/14t8uR947Z0","url_pic":"https:\/\/www.up3d.com\/face\/model\/w15.png"},{"title":"Pause and resume the 3D Printer","url":"https:\/\/www.youtube.com\/embed\/QA9UT58HVDE","url_pic":"https:\/\/www.up3d.com\/face\/model\/w16.png"}]
SendRequestToServer END OK:https://www.up3d.com/?r=client/bannerapi Receive:[{"url":"https:\/\/www.up3d.com\/blog\/?p=307","path":"https:\/\/www.up3d.com\/upload\/banner\/14787466420722.jpg"},{"url":"https:\/\/www.up3d.com\/blog\/?p=307","path":"https:\/\/www.up3d.com\/upload\/banner\/14785855316444.jpg"},{"url":"https:\/\/www.up3d.com\/?r=upboxplus","path":"https:\/\/www.up3d.com\/upload\/banner\/14781549797404.jpg"}]
GetPrinterInformation from config success
GetPrinterInformation Printername: 75525 SN: 0
SetPlaneSize -120 0 0 120 130
Thread_BEGIN_UpdateOtherStatus
WM_PAINT
用户双击模型,打开程序与模型:C:\Program Files\UP Studio\win64\UPStudio.exe
before CefExecuteProcess
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\go_back.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\self_model.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\save_model.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\share_model.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\buy_model.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\model_save.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\fail_warn.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\model_asave.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\layui-close1.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\add-stl.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\add-image.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\cube.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\sphere.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\cylinder.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\cone.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\ring.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\six_prism.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\surface.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\surface_choose.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\wrap.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\wrap_choose.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\very_fine_blur.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\very_fine_focus.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\nBig Hole.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\nBig Hole_choose.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\nHollow.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\nHollow_choose.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\nLoose.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\nLoose_choose.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\nsoild.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\nsoild_choose.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\very_dense_blur.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\very_dense_focus.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\next_onfocus.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\refresh.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\p.png
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\lib\image\color-default\clear.gif
SendRequestToServer END OK:https://www.up3d.com/winnipeg/api?apiName=uploadServiceInfo&serviceInfo={'Date':'2017-01-31%2023:01:24','Language':'en','Os':'Microsoft%20Windows%2010','CurrentVer':'1.5.1.1','PrinterSN':'000000','Count_Model_Rotate':'3','Count_Model_Scale':'5'} Receive:{"result":0,"code":"00200","message":"Succeed to upload the service info."}
BackServiceThread 传送成功
Send:https://www.up3d.com/winnipeg/api?apiName=uploadServiceInfo&serviceInfo={'Date':'2017-01-31 23:01:24','Language':'en','Os':'Microsoft Windows 10','CurrentVer':'1.5.1.1','PrinterSN':'000000','Count_Model_Rotate':'3','Count_Model_Scale':'5'}
Thread_BEGIN_ChromeBrowserCallback::async_read_printer_status
async_web_load_finished END
vbo support!
OpenGL version is : 4 framebuffer support OK!
SetUpMultiSample frameBufferStyle: 1
GetBannerInfo_Json OK:[{
"url": "https://www.up3d.com/blog/?p=307",
"title": "",
"path": "tiertime://crypte/C:%5CUsers%5CDaniel%20Parker%5CAppData%5CRoaming/Tiertime/Data/Banner/14787466420722.jpg"
"title": "",
"path": "tiertime://crypte/C:%5CUsers%5CDaniel%20Parker%5CAppData%5CRoaming/Tiertime/Data/Banner/14785855316444.jpg"
"url": "https://www.up3d.com/?r=upboxplus",
"title": "",
"path": "tiertime://crypte/C:%5CUsers%5CDaniel%20Parker%5CAppData%5CRoaming/Tiertime/Data/Banner/14781549797404.jpg"
SendRequestToServer END OK:https://www.up3d.com/huland/api?apiName=checkLogin&tranId=BQMA6HhmUV Receive:{"result":0,"tranId":"BQMA6HhmUV","code":"00200","traceUserData":"1","expire":"7776000","nickname":"Xonor13","message":"The status of login is normal.","userId":"33e4ef02-add0-11e5-9d94-d8cb8a7499d8"}
RunJSFunc 1 SYNC.Login('33e4ef02-add0-11e5-9d94-d8cb8a7499d8','BQMA6HhmUV','Xonor13');
AutoLogin OK,UserName: Xonor13
SendRequestToServer END OK:https://www.up3d.com/winnipeg/api?apiName=uploadServiceInfo&serviceInfo={'Date':'2017-01-31%2015:29:02','Language':'en','Os':'Microsoft%20Windows%2010','UserID':'33e4ef02-add0-11e5-9d94-d8cb8a7499d8','PrinterSN':'75525','PrinterModel':'UP%20mini','Material':'PLA','RemainedMaterail':'129','NozzleTemp':'210','PlatTemp':'46','ModelName':'pangolin....ll.stl','ModelFacetNum':'10276','ModelSize':'101.411x101.411x26.2749','LayerThick':'0.2','FillStyle':'Loose','Quality':'NORMAL','MaterialUsed':'28.97','PrintTotalTime':'223m','CurrentVer':'1.5.1.1'} Receive:{"result":0,"code":"00200","message":"Succeed to upload the service info."}
Send:https://www.up3d.com/winnipeg/api?apiName=uploadServiceInfo&serviceInfo={'Date':'2017-01-31 15:29:02','Language':'en','Os':'Microsoft Windows 10','UserID':'33e4ef02-add0-11e5-9d94-d8cb8a7499d8','PrinterSN':'75525','PrinterModel':'UP mini','Material':'PLA','RemainedMaterail':'129','NozzleTemp':'210','PlatTemp':'46','ModelName':'pangolin....ll.stl','ModelFacetNum':'10276','ModelSize':'101.411x101.411x26.2749','LayerThick':'0.2','FillStyle':'Loose','Quality':'NORMAL','MaterialUsed':'28.97','PrintTotalTime':'223m','CurrentVer':'1.5.1.1'}
Thread_END_BackServiceThread
[USB Lock Error] GetMotorPos
====== CANCEL
====== CANCEL OK
Cancel Detail ====
Cancel Detail OK ====
async_setfocus_disc:0
[USB Lock Error] GetPrinterStatus
ConnectPrinter[USB]:75525 Error
'Date':'2017-02-06 15:33:16',【PrinterStatusChange】PrinterString : Printer not Connected NEW:-1 OLD:-2
'Date':'2017-02-06 15:33:16',【PrinterStatusChange】MaterialChange Name : ConnectType:0 Material:PLA
【HeatStatus Changeto 】0
2017/02/06 15:33:16.401 async_read_printer_info
[PrinterChanged] Relinked
【UpdatePrinter】 打印机重新连接,更新打印机信息与平台尺寸
GetPrinterInformation from printer success
GetPrinterInformation Printername: 75525 SN: 75525
SetPlaneSize2-12000120130
[PrinterChanged] SN changed to 75525
'Date':'2017-02-06 15:33:20',【PrinterStatusChange】PrinterString : Printer not Initialized NEW:0 OLD:-1
'Date':'2017-02-06 15:33:20',【PrinterStatusChange】PrinterChange NameChange Name : 75525 ConnectType:0 Material:PLA
2017/02/06 15:33:20.622 async_read_printer_info
CheckActive Begin
FirmwareVer<345,return
SendRequestToServer END OK:https://www.up3d.com/winnipeg/api?apiName=getDeviceParameters&id=10003&online=1 Receive:{"result":"1","message":"未找到对应的设备属性。"}
GetPrintParamFromServer ERROR:(10003): 未找到对应的设备属性。
'Date':'2017-02-06 15:33:22',【PrinterStatusChange】PrinterString : Printer not Initialized NEW:0 OLD:0
DESTORY MSGBOX: Initialize Printer?
Initial Printer ...
Initial Printer Finished
RunBreakLayer Begin
RunBreakLayer error: FirmwareVer < 351
nStatus <0, bReLinked=true change to false; status: -1
async_setfocus_disc:1
'Date':'2017-02-06 15:33:51',【PrinterStatusChange】PrinterString : Printer not Connected NEW:-1 OLD:0
'Date':'2017-02-06 15:33:51',【PrinterStatusChange】PrinterChange NameChange Name : ConnectType:0 Material:PLA
Load3DModel C:\Users\Daniel Parker\Desktop\3D Printer\3D Designs\egg.stl
thread_read_3dmodel_list Begin
loadmodel:C:\Users\Daniel Parker\Desktop\3D Printer\3D Designs\egg.stl
thread_load_3dmodel_monitor End
AddRecentFile C:\Users\Daniel Parker\Desktop\3D Printer\3D Designs\egg.stl
loadmodel finished
thread_read_3dmodel_list End
RunJSFunc 1 SYNC.model('1','1','1','1');
Initial Printer ...
2017/02/06 15:33:57.738 async_read_printer_info
2017/02/06 15:34:11.733 async_read_printer_info
async_print_exit_page
Initial Printer Error
2017/02/06 15:34:11.836 async_read_printer_info
2017/02/06 15:34:11.866 async_read_printer_info
2017/02/06 15:34:11.889 async_read_printer_info
'Date':'2017-02-06 15:34:34',【PrinterStatusChange】PrinterString : Printer not Initialized NEW:0 OLD:-1
'Date':'2017-02-06 15:34:34',【PrinterStatusChange】PrinterChange NameChange Name : 75525 ConnectType:0 Material:PLA
2017/02/06 15:34:34.856 async_read_printer_info
CheckActive Begin
async_axis_lighton 3
RunJSFunc 1 SYNC.axisLightOn('3');
async_zoom 3 0.8
RunJSFunc 1 SYNC.canReturnBackAStep('1');
async_zoom 3 0.0009
async_zoom 3 0.9
async_zoom 3 0.9000
async_zoom 3 0.9000
async_zoom 3 0.9000
async_zoom 3 0.9000
async_zoom 3 1.1
Initial Printer ...
RunBreakLayer Begin
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\pack\image\up\color-default\upload_wait.gif?t=0.4296059135138244
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\pack\image\up\color-default\upload_wait.gif?t=0.2944086837563207
LoadScheme2 Error ShortPath: C:\Program Files\UP Studio\win64\scheme2\pack\image\up\color-default\upload_wait.gif?t=0.20095851170694434
Model_GetUploadImage:egg.stl
((((((())))))) tiertime://crypte/C:/Users/Daniel%20Parker/AppData/Roaming/Tiertime/Temp/UpLoad/wholeview_1.bmp
((((((())))))) tiertime://crypte/C:/Users/Daniel%20Parker/AppData/Roaming/Tiertime/Temp/UpLoad/wholeview_2.bmp
((((((())))))) tiertime://crypte/C:/Users/Daniel%20Parker/AppData/Roaming/Tiertime/Temp/UpLoad/wholeview_3.bmp
'Date':'2017-02-06 15:36:06',【PrinterStatusChange】PrinterString : Printer not Connected NEW:-1 OLD:0
'Date':'2017-02-06 15:36:06',【PrinterStatusChange】PrinterChange NameChange Name : ConnectType:0 Material:PLA
thread_async_upload_enter END
GetCurrentVersion 1.5.1.1
2017/02/06 15:36:12.613 async_read_printer_info
Tiertime_Betty
Post by Tiertime_Betty » Fri Mar 10, 2017 4:12 pm
We are so sorry for the inconvenience. Our dev-team has did a serial of tests and never reproduce the bug. And we suggest you to update your software to the latest version--v1.6.1.1(which has a new function in print setting page----names "clear SD card"), you can use this function to reset your printer.
Code: Select all
WM_PAINT
vbo support!
"title": "",
"title": "",
"title": "",
====== CANCEL
====== CANCEL OK
Cancel Detail ====
CheckActive Begin
Initial Printer ...
RunBreakLayer Begin
loadmodel finished
Initial Printer ...
CheckActive Begin
async_zoom 3 0.8
async_zoom 3 0.0009
async_zoom 3 0.9
async_zoom 3 0.9000
async_zoom 3 0.9000
async_zoom 3 0.9000
async_zoom 3 0.9000
async_zoom 3 1.1
Initial Printer ...
RunBreakLayer Begin
Last edited by Tiertime_Betty on Fri Mar 10, 2017 4:14 pm, edited 2 times in total.
Tiertime_Betty
Code: Select all
WM_PAINT
vbo support!
"title": "",
"title": "",
"title": "",
====== CANCEL
====== CANCEL OK
Cancel Detail ====
CheckActive Begin
Initial Printer ...
RunBreakLayer Begin
loadmodel finished
Initial Printer ...
CheckActive Begin
async_zoom 3 0.8
async_zoom 3 0.0009
async_zoom 3 0.9
async_zoom 3 0.9000
async_zoom 3 0.9000
async_zoom 3 0.9000
async_zoom 3 0.9000
async_zoom 3 1.1
Initial Printer ...
RunBreakLayer Begin
