Turn the lights on, will ya?!
Rootz
Post by Rootz » Fri May 24, 2013 8:48 pm
Guys,
I see no mention of this in the manual but I did notice some LED's mounted around the extruder head and wired into the main ribbon cable. I assume they're supposed to come on when the unit is printing but, no joy. I've buzzed the wires through and no problems there so I can only guess there's something I have to do, like press the button while I turn the unit on and simultaneously stand on one leg while humming the theme from Dirty Dancing and doing a Popeye impression. I tried that. Didn't work. :roll:
Any ideas??
Cheerz!
R :shock: tz
scubamatt41
Re: Turn the lights on, will ya?!
Post by scubamatt41 » Fri May 24, 2013 10:02 pm
Wrong wrong wrong, you have to hum the national anthem of the People's Republic of China.
Or you double click (like on a mouse button) on the on/off switch after you power the printer on. Can be done directly after power UP ;)
Post by roller » Sat May 25, 2013 1:17 am
I had a Mini but have since switched to a Plus so this is from memory ... you have to double click the initialize button. It seems to want a specific double-click speed so there is a bit of a knack to it - once you've go it you can turn on and off easily though I don't recommend trying once a job has start as I did accidentally re-initialise a couple of times which killed my print.
Rootz
Post by Rootz » Sat May 25, 2013 1:23 pm
Mucho thanks Matt and Roller,
Glad I can do it with the button; The Chinese National Anthem lasts 47 minutes! And that's the short version. :o
Cheerz!
R :shock: tz
scubamatt41
Post by scubamatt41 » Tue May 28, 2013 8:35 pm
BUMP
Post by roller » Fri May 31, 2013 6:06 am
Why did this topic need a bump - was something left unanswered?
scubamatt41
Post by scubamatt41 » Fri May 31, 2013 7:51 am
No roller, all the answers someone could be looking for if they where actually looking :)
It's is my opinion that some anwers are allready on this forum. Hey, look at the top, do I really see a search option, wauw
Post by roller » Fri May 31, 2013 10:35 am
Huh? I was just curious why you bumped?
samspqr
Post by samspqr » Sun Oct 20, 2013 2:13 am
Thanks for this, I will try it tomorrow. Can't do it now because of a different firmware issue: if I turn it on, it will beep and wake up the missus.
While they're at it: the LEDs should turn on by themselves whenever you start doing something related to platform calibration.
SeaweedCrisps
Post by SeaweedCrisps » Mon Nov 11, 2013 4:06 pm
i love the lights....but the little clip that hold it in place broke off mine waaaah
http://www.myminifactory.com/ - free 3D file sharing platform
