Need help about belt position
Oral
Post by Oral » Mon Apr 15, 2013 9:47 am
SlippedBelt-2.jpg[/attachment]
Slipped belt-1
Hi ,
My Up! Mini's x-axis drive belt slipped to downwards. And the tensioning clips on the belt touches to plastic part for bedding. I must move the belt upwards to solve this problem. But the belt is quite tight to move it. I'm waiting to your suggestions on the issue. Otherwise the belt , the clips or the bedding will be damaged.
thank you all .
Slipped belt-2
Re: Need help about belt position
Post by wackojacko » Tue Apr 16, 2013 6:58 am
If you hold the belt, you will be able top slide the spring along to it's correct position.
Oral
Post by Oral » Fri Apr 19, 2013 7:20 pm
I placed it to normal position. But after running the machine it again slipped downward.
