Help! The Item Printed Is Shifting to the right!
used3995
Post by used3995 » Thu Nov 03, 2016 9:17 pm
I have a UP MINI model 3DP-10-4B s/n 208969 ROM V6.100 firmware V3.30
I have a windows XEON dual core PC 64 bit with 10GB memory and Windows 8.1
Was printing fine, now it prints, then after awhile everything SHIFTS to the right! then keeps printing then SHIFTS to the right again! etc.
I am using the control software V2.18 and I also tried the :
UP Studio For Windows x64 Version:1.3.2.3 (did not install at all)
I installed UP Studio For Windows x64 Version:1.3.2.2 and this Works, but I get the same shift error
so I went back and am using the 2.18 and I like this, this works fine, it initializes, calibrates etc.
but I keep getting this "Shift to the right"error--- (see pictures!!)
was printing fine, now it prints, then after awhile everything SHIFTS to the right! then keeps printing then SHIFTS to the right again! etc. Please help me! :cry:
Tiertime-Jason
Re: Help! The Item Printed Is Shifting to the right!
Post by Tiertime-Jason » Mon Nov 07, 2016 1:57 am
Is there anything hindering the movement of the print head?
Are the shifiting only occur in very specific height or just random?
Tiertime-Jason
Post by Tiertime-Jason » Tue Nov 08, 2016 9:38 am
Wargass
Post by Wargass » Mon Dec 19, 2016 3:29 am
I am having a similar issue, not as drastic and to the left. but there is nothing blocking the print head
ccooksey
Post by ccooksey » Thu Apr 27, 2017 4:57 pm
I am having the same issue as the original poster, mine shifts to the right. I've measured and it usually happens every 19-19.5 mm. It is very annoying and a big pain in the <you know what>. Has anyone figured this out yet?
Scirocco
Post by Scirocco » Tue Jun 20, 2017 3:14 pm
I had a similar problem with my up mini as you can see in the attachment.
After opening the printers back, unplugging and replugging the microSD card everything is back to normal.
Maybe that helps.
