Light not working when I want it to, please help
So, i've had no problems with my light not working before and now when I hit the button on the front of the printer, it doesn't turn the light on at all. And I understand it has to be initialized to be able to use it, it is. I also found that when I double click the button, it starts to print an old design that I cancelled. please help
Re: Light not working when I want it to, please help
That is weird, as far as I know the Up Mini doesn't support the double click print again.. Did you somehow manage to get Up Plus firmware on your Up Mini or do you have another CPU?
- Tiertime-Jason
May be something wrong with the led strip on the print head?
Later models of UP mini did have "double press - reprint" function. We added it back.
I am using the newer UpStudio softwareUP_3DWP wrote:???
So I noticed that when I print an object the light automatically turns on, but it is very weak (weaker than normal.) It does not normally turn on by itself. Then when I hit the button the light turns off and I am not able to turn it back on, I have to wait for it to turn back on by itself. Even then it is way to dim for me to see anything. Sorry I'm new to UP forums and not exactly a pro with it. Thanks for the help!
