Extruder stepper getting extremely hot
tobih
Post by tobih » Fri Jun 17, 2016 6:07 pm
the stepper motor of the up! mini extruder ist getting extremely hot, way above 60 °C.
The type says it is a nema-17 stepper "17HD....."
Can I somehow change the max. current, e.g. on the mainboard (for example pololu a4988 have a potentiometer on-board)?
The problem is that the magnets will lose some of their power, and the whole head is about to "fall off".
brainzilla
Re: Extruder stepper getting extremely hot
Post by brainzilla » Sat Jul 02, 2016 11:51 am
Is that after prolonged use or happening fast?
One or two fans for the motor will help, but maybe your driver is malfunctioning / "latching up".
Otherwise it prints fine?
MadMatt
Post by MadMatt » Mon Jul 18, 2016 4:34 am
I have no problems with the magnets but my stepper gets that hot too, even without printing.
It prints fine IF it prints (i have troubles with filament feeding and do not know wether it's related to the temperature of the stepper)
3DWP
Post by 3DWP » Thu Sep 08, 2016 4:31 pm
Any solution for this?
I have an extremely hot stepper too and don't know how to fix it. I can't even print OEM ABS anymore..
NicoBombara
Post by NicoBombara » Mon Sep 04, 2017 3:28 pm
Someone could fix it? I have the same problem
Glem3d
Post by Glem3d » Wed Mar 28, 2018 11:09 pm
boa noite
remova o filamento da impressora
remova a parte de plastico que tem o cooler
mova a engrenagem do motor para um lado e outro para verificar se ele não esta muito pesado
se não estiver coloque um ventilador na frente para fazer o teste, eu fiz isso nas minhas e parou de dar o problema.
Se funcionar, coloque outro cooler acoplado ao lado do motor.
