Metal pad on stepper motor for magnet
snakesrules
Post by snakesrules » Thu Mar 10, 2016 2:04 pm
Hi all , it's the third time that the little metal pad on stepper motor used to maintain it on the magnet falls apart .
I use some classic " rapid glue " to put it back in place but it doesn't last very long with the temperature and the vibrations i think .
This time is use another glue which should be strong enough up to 120°C , i will see .
Did someone ever experienced this problem and how to fix it for a long time ?
Of course , i clean both stepper side and metal pad side before applying glue .
Tiertime-Jason
Re: Metal pad on stepper motor for magnet
Post by Tiertime-Jason » Fri Mar 11, 2016 4:22 am
Commonly avaliable two part glue should be ok.
brainzilla
Post by brainzilla » Thu Mar 17, 2016 4:01 pm
2k Acrylate usually does the trick.
Also install some extra fans on your stepper to keep it cooler.
