Matchpoint
Post
by Matchpoint » Wed Feb 17, 2016 9:01 pm
few questions.
Same material and brand?
Was the enclosure closed both times?
Did you move or alter the printer in any way from printing one day to the next?
What was the time of day/outside conditions for both prints?
snakesrules
Post
by snakesrules » Wed Feb 17, 2016 9:42 pm
hi ,
material is ABS for both print at L1 235° / L2 230° / L3+ 220° ( softmod )
blue one is from Velleman, black one from Esun .
Enclosure is always closed , bed at about 80° ( temp mod ) and almost same conditions ( 20° in the room ) when printing .
I also didn't change nor redo the platform calibration between the differents print .
Matchpoint
Post
by Matchpoint » Wed Feb 17, 2016 10:40 pm
which was printed first?
It definitely looks to appear to be something relating to the material itself. Its awfully stringy and a mess on the blue parts.
snakesrules
Post
by snakesrules » Thu Feb 18, 2016 12:01 pm
Not sure but the fact is that i've tried with an ABS i'm sure about it and the result is the same .
I think i will give it a try after recalibrating the platform .
I used to have a 0.2mm clearance between bed and nozzle but as i have a Bluetak film on my platform , maybe the clearance is a bit too high now .
I will try with 0.1mm clearance and let you know after .
Matchpoint
Post
by Matchpoint » Thu Feb 18, 2016 2:19 pm
Take a picture of the first layer the printer puts down. That way we can see the height too.
ricks01
Post
by ricks01 » Thu Feb 18, 2016 11:05 pm
Can you post the stl file for the part?
snakesrules
Post
by snakesrules » Fri Feb 19, 2016 12:09 pm
yes i will post it tonight .
I tried yesterday to change my temp settings : i was at L1 235° / L2 230° / L3+ 220° and i changed to L1 255° / L2 250° / L3+ 240° and the result is much better ! more coherency on the first layers
dario.t
Post
by dario.t » Fri Feb 19, 2016 12:43 pm
Hi snakesrules
From my experience and how the prints look like I do assume that the printing temperature is too low.
If you are just in a try phase, go for much higher temperatures:
250 - 260°C
I think that the ABS is just not hot enough to "glue" with the other layers. The plastic coming out of the nozzle still needs to heat up the layer below to get proper adhesion.
I have realized that even with the recommended print temperatures the result isn't as it should be. So I had to run test prints to find the right temperature.
Have you done any other prints in between?
I hade once a similar problem with one of my "none" UP! printers and there it was a extruder/nozzle problem. I had to clean everything and reset the tension of the extruder spring. Then it printed again as it should.
Please check the feeder of your up mini (if you haven't done it already)
Give that all a try.
Cheers
Dario
Matchpoint
Post
by Matchpoint » Fri Feb 19, 2016 2:37 pm
It looks to me like your nozzle height is to high as well as temperature to low. Can you take a picture of the first layer as it is printing on the perf board.
snakesrules
Post
by snakesrules » Fri Feb 19, 2016 3:58 pm
Hi , my clearance between nozzle and platform is less than a sheet of paper so i thinks it's OK but as pointed by dario.t and in my previous post , the temperature is the key : i test a quick print yesterday evening with 20°C more on all layers and the result is much better than before .
Matchpoint
Post
by Matchpoint » Fri Feb 19, 2016 4:01 pm
I run most of my abs around the default UP software temp 260, and I have never had a problem. I usually run PLA at around 210 ish.
brainzilla
Post
by brainzilla » Thu Mar 17, 2016 4:07 pm
I found that orientation and order of parts plays a role too.
I print 90% raftless, so the first layer is key to success.
Some directional combinations seem to tend ripping off / loose contact, others do better.
Also filament-diameter and other parameters may affect the amount of material put out.
I always check while printing the first layer and manually press up the bed to get closer to the nozzle.
If it fails, I stop and immediately re-print and try to match the fault by pressing again.
Also make sure your blue tape is always sticky. I rub it with iso-2-pro once in a while - that makes it sticky again.
