change color/filament during print
3DSTB
Post by 3DSTB » Fri Feb 12, 2016 6:22 pm
is is possible to change to color/filament during print? In the print options is a stop/break at layer .... Can i use this to stop the print change the filament, extrude until the color is ok and resume the print?
Re: change color/filament during print
Post by wackojacko » Fri Feb 12, 2016 6:49 pm
Is the print screen there is pause at layer, just set what height in mm and the printer will pause, then goto maintenance withdraw, then extrude new color and resume. 2,5 will pause at your model z height 2mm and 5mm
brainzilla
Post by brainzilla » Wed Feb 17, 2016 1:08 am
Make sure to use a POINT instead of the COMMA!
So 2.5 instead of 2,5…
And you can also manually pause and resume.
Multicolor-prints are pretty!
ricks01
Post by ricks01 » Wed Feb 17, 2016 4:48 am
brainzilla wrote:Make sure to use a POINT instead of the COMMA!
Well the comma is used when doing multiple pauses. For example 2.5, 5.5, 7.5 would make the printer pause at 2.5mm, then 5.5mm and then finally 7.5mm.
tel
Post by tel » Wed Feb 17, 2016 9:08 am
Does the pause height ignore the raft? I'm trying to stop at an exact spot in the print which I have worked out using the plane feature in meshmixer, but the print always stops before it should. Wondering if this is due to it counting the raft as well.
Post by wackojacko » Wed Feb 17, 2016 6:45 pm
It ignores the raft, so it's actual z height in mm
