[BUG REPORT] Issue relative with parts base flatness
pablo.rodriguez
Post by pablo.rodriguez » Thu Jan 21, 2016 7:35 pm
I own a UP mini and I’m suffering an issue relative with parts base flatness
The base of all pieces I print is not flat, the end of the base is always elevated at the end side.
Is very significant in large pieces
But it happens also in small ones:
I suspected about the platform calibration, but I have calibrate it and the problem persist. I tried to print with the part in distinct orientations and platform positions but it is always the same result
Thanks in advance for your help
Matchpoint
Re: [BUG REPORT] Issue relative with parts base flatness
Post by Matchpoint » Fri Jan 22, 2016 2:39 pm
Are you printing with ABS? abs is prone to warping. This looks more of a warp issue, like it is unbinding from the raft during printing. Is there any reason you are standing the "name plates" up like that instead of laying them down?
I would suggest the following:
-laying them flat for best adhesion
-make sure your bed is properly heated
-keep the enclosure closed to keep the heat in
-check the door on the print head to see if its open or closed
-try printing on a different setting (i.e. "fine" mode)
