Heated Bed Question
RKov
Heated Bed Question
Post by RKov » Tue Feb 24, 2015 8:57 pm
Does anyone know exactly what the stock bed temperature is set at on the newest UP! Mini?
SeeJaysPlace
Re: Heated Bed Question
Post by SeeJaysPlace » Mon Apr 06, 2015 4:54 pm
60c
Post by roller » Sat Apr 11, 2015 5:20 pm
SeeJaysPlace wrote:60c
Or more specifically it is heated by a 60C heater module. There is nowhere to "control" the temp. To get a higher temp (which I expect you will need) you need to replace this module. Some have done 80C and 90C (or was it 100C) modules successfully. You will find printing a lot more successful with ABS if the temp is at least 80C
yo3ggx
Post by yo3ggx » Mon Apr 20, 2015 10:38 am
I've done a dual bed temp mod (60/100C).
The problem is that the bed heating grid in Mini is barely able to heat more than 70-80C in the best case, even after one hour.
Anyone tried to use some additional heating resistors? The bed is powered at around 18V.
Dan
Post by roller » Mon Apr 20, 2015 6:23 pm
The other and bigger issue is that it is rarely uniform ... when 60+ in the centre it's often only 50C in the corners and that's a lifting nightmare on difficult prints.
