HELPPPPP
marshy147
HELPPPPP
Post by marshy147 » Sat Jan 31, 2015 10:21 am
2nd time now this happened, nozzle is on tight as can get it but black gunk appears round nozzle and when try to take it off it's impossible, it's like its welded on!!
Any ideas
Re: HELPPPPP
Post by mr6k » Mon Feb 02, 2015 10:17 am
hi,
on no account try to remove the nozzle when it is cold, you will shear it off.
set the printer to withdraw or extrude and once the nozzle is up to tempersture (260 degrees), you should be able to remove the nozzle with the tool provided.
Refit the nozzle cold, do not tighten it further when hot.
once you have done this younwill need to do a new nozzle height calibration as, in my opinion, the nozzle never sits at exactly the same height after removal and refit.
