guide to replace hotend (e3d v6)
ewewo
Post by ewewo » Mon Jan 26, 2015 9:40 am
hey,
is there any guide to build in an e3d v6 hotend?
7Schlaefer
Re: guide to replace hotend (e3d v6)
Post by 7Schlaefer » Mon Jan 26, 2015 10:39 pm
I doesnt seen one. But actualy i build a new extruder frame, to fit the V6 hotend.
Only problem is, you loose about 30mm printable height.
Grüße Leo
ewewo
Post by ewewo » Tue Jan 27, 2015 7:21 am
Cool, was denkst, wann ist es ready for public?
7Schlaefer
Post by 7Schlaefer » Tue Jan 27, 2015 12:47 pm
First i need my spare parts for my current headblock :( Give me a mounth or two ;)
7Schlaefer
Post by 7Schlaefer » Sun Feb 08, 2015 4:36 pm
So .. the hotend is mounted.
BUT
The software want working, if the nozzle height is lower than 115mm (about 85mm with the V6).
Perhabs they can fix this in the software. But somebody told me they have printed on 50mm stages without problems :(
I tried differnt software versions 2.13 / 2.12 / 2.11 .. none worked with a lower level.
Post by DrewPetitclerc » Mon Feb 09, 2015 3:01 am
I switched to a Recreus design of hot end and had to shorten it due to this same issue.
Next time I plan to add material to the mount bracket for the extruder to the slide saddle to raise the extruder up to regain the lost height.
You might try this option.
Drew
7Schlaefer
Post by 7Schlaefer » Mon Feb 09, 2015 4:45 pm
Yes, as i told in the facebook group, i try to get the extruder external working.
Its not easy without printer to get the parts :D
Acutally i try to construct a external mounting from a old parts that ive printed. Only problem to get the head temporary in position, till i printed a good mounting :D
7Schlaefer
Post by 7Schlaefer » Mon Feb 09, 2015 5:51 pm
