No Perf Plate
Deet
No Perf Plate
Post by Deet » Tue Aug 12, 2014 11:03 am
Hi all
Just received my Up Mini today, and much to my distress I couldn't find the perf plate anywhere in the box
Where is it usually packed?
Just so I can try and print something, what could I use as a substitute plate until (I assume) a replacement plate is shipped to me
Re: No Perf Plate
Post by mb20music » Wed Aug 13, 2014 1:42 am
I think they put them in the small cardbox box that contains all the tools - the scraper, xacto knife, etc.
You probably should contact the distributor you purchased your unit from for replacements. I believe it is supposed to come with 3 perfboards.
wilsonj
Re: No Perf Plate
Post by wilsonj » Wed Aug 13, 2014 8:01 am
Bummer!
If you can cut a piece of 3mm acrylic 140x140 that will do the trick. Otherwise you might find one in the post tomorrow....
scubamatt41
Re: No Perf Plate
Post by scubamatt41 » Wed Aug 13, 2014 12:24 pm
psst, 3mm thick build plates doesn't work on the mini. Unless you remove the heat bed and install a thinner washer to replace the little L shaped mounting bracket.
I don't think Deet wants to do that with a brand new UP mini :?
Cutting PMMA or PC works but NOT thicker than 2mm. Preferably 1.5mm thick
wilsonj
Re: No Perf Plate
Post by wilsonj » Wed Aug 13, 2014 12:49 pm
scubamatt41 wrote:psst, 3mm thick build plates doesn't work on the mini. Unless you remove the heat bed and install a thinner washer to replace the little L shaped mounting bracket.
Oops you are right, my bad. 2mm.
wilsonj
Re: No Perf Plate
Post by wilsonj » Fri Aug 15, 2014 4:30 am
Hi Deet, did you end up getting a board ok ?
Deet
Re: No Perf Plate
Post by Deet » Fri Aug 15, 2014 7:16 am
I did get the plate thanks, and the new ones from the supplier arrived law today
Look forward to some filament orders as my way of saying thanks
wilsonj
Re: No Perf Plate
Post by wilsonj » Fri Aug 15, 2014 11:32 am
No probs, glad to have helped.
