Nozzle Heater
menno
Nozzle Heater
Post by menno » Tue Mar 18, 2014 8:22 pm
Today I started to manufacture my own nozzle heater.Can someone help me with information of the heater?I mean the Voltage and Watts of the heater.
Menno
changfrancis
Re: Nozzle Heater
Post by changfrancis » Wed Mar 19, 2014 2:58 pm
UP using diff heater and temp sensor from reprap, hence pls be careful in selection.
UP is a 19V-20V system.
menno
Re: Nozzle Heater
Post by menno » Wed Mar 19, 2014 6:50 pm
Thank you for your reply.Can you tell me what kind of type heater and sensor I need?
Thanks,
Menno
Re: Nozzle Heater
Post by roller » Thu Mar 20, 2014 3:42 am
I believe the sensor is a 100ohm platinum RTD with a 0.00392 coefficient temperature (in Celsius not Fahrenheit). Not bothered to look at the heater yet so can't help there.
menno
Re: Nozzle Heater
Post by menno » Sun Mar 23, 2014 9:56 am
Thank you Roller!I replace the sensor with a flat Pt100 and made a little block.Then I inserted the sensor on the flat milled surface.It prints perfectly.
Menno
DSC01078 - kopie.JPG (112.75 KiB) Viewed 7290 times
Oland
Re: Nozzle Heater
Post by Oland » Sun Mar 23, 2014 3:14 pm
Nice design I also want to have
maybe this helps
I measure:
heater:
Met de Ohm meter ~ 7,5 Ohm
op weg naar "extrude" 2,5Amp ~ 18,4 Volt DC
tijdens "extrude" geen DC maar wordt PWM ~50% duty cycle volgens de scoop
sr for my dutch/english
Hans
tommyboymustdie
Re: Nozzle Heater
Post by tommyboymustdie » Sun Mar 23, 2014 11:47 pm
I took apart mine and this is what it reads on the heating element:
Annal 24V
1202 80W
Is there a chance you can make a copy of the heating block for me as well?
menno
Re: Nozzle Heater
Post by menno » Tue Mar 25, 2014 8:56 pm
I can not make the hole heating block for you.The round stainless steel part I made not on a CNC machine but on a conventional lath machine.
The aluminium block I made on a 5-axis Milling machine.I can make the aluminium block for you.To make the rest is taking me to much time..sorry
Menno
