Move Errors
Steveb56
Move Errors
Post by Steveb56 » Mon Dec 31, 2012 5:27 pm
I am getting constant move errors on some of my prints. Why does this happen?
I can print many items, but when I have something with maybe 250 - 500 steps, the Mini gives me the move error.
I have tried with the cover closed and also opened.
Is there something wrong with my printer?
Thanks ahead for any guidance.
r03ert0
Re: Move Errors
Post by r03ert0 » Thu Jan 03, 2013 3:56 pm
I'm also getting the infamous Move Error....
I'm trying to print a model which is 272 layers, and it has stopped twice at about the same level (layer 47).
Some people seem to get 'Move errors' when the X, Y or Z switches are failing. That had already happened to me (I have an old Up, with optical switches ), but in that case the printer fails to move in one of the directions, and mine is moving correctly up/down, left/right, front/back... So, I don't think it's an axis-switch problem...
but then, what could it be? Would it be possible that my model file has something that make the printer stop? Could it be a loose connection? Is there a way of getting more information about what is actually going wrong???
By the way, I'm using v1.3 in a mac.
thank you for your help!
roberto
Re: Move Errors
Post by DrewPetitclerc » Thu Jan 03, 2013 7:27 pm
I've found this to be a "Hot electronics" error, not enough air flow across the main board and the stepper controller on the far left (X controller) was overheating.
If you have any restriction of airflow from the right to left, there is a very small fan in there that could be the culprit.
r03ert0
Re: Move Errors
Post by r03ert0 » Fri Jan 04, 2013 10:15 am
DrewPetitclerc wrote:I've found this to be a "Hot electronics" error, not enough air flow across the main board and the stepper controller on the far left (X controller) was overheating.
thanks Drew.
I'll try taking of the cover, and maybe adding an extra fan (i may have one around...)
cheers,
roberto
r03ert0
Re: Move Errors
Post by r03ert0 » Fri Jan 04, 2013 11:13 am
argh.... just tried again with the new UP software (1.4 mac, osx 10.8.2), Move Error: Layer 5... I checked the temperature in the stepper motor drivers, and they seem Ok (after 5 layers, it would be surprising if they were too hot...). Additionally, v1.4 is constantly freezing!! (I have to force quit to exit) it's quite annoying.... I'll try again but with version 1.3 this time
(i liked the new stepper motor music in v1.4, though :D)
