I cant send more than 100 layers to UP! mini
ljuboizsiska
Post by ljuboizsiska » Tue Dec 04, 2012 3:38 pm
When I try to send object that have more than 100 layers it is impossible to send layers. Up software is stuck in sending layer no.1. and lamp on my printer is blinking rapidly in diferent colours. Please help! I have this printer only 3 months and usualy is working great. I use it for printing surgical guides for implant placement in dentistry.
Re: I cant send more than 100 layers to UP! mini
Post by wackojacko » Tue Dec 04, 2012 5:52 pm
This is normally an error on the SD card or a problem on the USB port. Try reseating the SD card.
ljuboizsiska
Post by ljuboizsiska » Tue Dec 04, 2012 10:03 pm
what is procedure to reset SD card?
Post by wackojacko » Wed Dec 05, 2012 9:12 am
Sorry I meant reseating - no resetting. That means unplug and re plug it in.
Post by roller » Thu Dec 06, 2012 1:36 am
Once you remove the back panel on the Mini the mainboard and microSD card (or was it MiniSD) will be fairly easy to see.
ARC-MODELS
Reset of SD of UP Plus
Post by ARC-MODELS » Mon Dec 31, 2012 8:53 pm
Where is the SD in the UP Plus ?.
Post by wackojacko » Tue Jan 01, 2013 2:58 am
On the back left hand side
amd-tec
Re: Reset of SD of UP Plus
Post by amd-tec » Tue Jan 01, 2013 7:34 am
ARC-MODELS wrote:Where is the SD in the UP Plus ?.
It's locatec in left side upper corner, see the picture.
SD-card location.
http://www.amd-tec.com
Post by wackojacko » Tue Jan 01, 2013 11:15 am
Thanks for posting the picture, wasn't around a PC at the time.
