HELP Nozzle height
Joren
HELP Nozzle height
Post by Joren » Sun Nov 10, 2013 1:36 pm
Hey,
Recently i have purchased a UP mini 3d printer. i have already successfully printed several objects.
However, now the printer requests a nozzle height. how do i determine the accurate height?
thanks!
ktronik
Re: HELP Nozzle height
Post by ktronik » Mon Nov 11, 2013 2:56 am
a quick and easy setup is to fold a piece of paper, place that between your print nozzle, and the perf board, set gap so paper can slide under, (~0.2mm) then set that as nozzle height...good idea is to heat up bed and nozzle, then set height... then re-test, to see how the raft is laid...gap to small and the feed stepper will skip on the filament...too much and it won't stick to the perf board...
hope this helps
K
