how does mini do it?
rogerw
Post by rogerw » Sun Oct 27, 2013 7:16 am
how does the printer 'print' to let you separate your part from the support material?
is the support material printed thinner or left to dry a split second longer ?
all seems to print the same to me but somehow you can peal the two apart.
roger.
Re: how does mini do it?
Post by DrewPetitclerc » Sun Oct 27, 2013 6:19 pm
The simple answer is, the "raft" and "support" are laid down first then the "part" material is placed then the next layer is started with the "oldest" area of "support/raft" is then covered with part material, this allowed the "support" to cool more thus not create as strong a bond.
If you watch carefully you will see each layer is always created in the same order.
First layer:
1. raft
2. support
3. part
second layer:
1. raft
2. support
3. part
repeat.....
Drew
Post by roller » Mon Oct 28, 2013 5:09 am
As drew says there seems to be some cooling allowed and there is also a change in layer heights so the part layers aren't pushed into the support layers like they are with a normal layer. But exactly what happens is the secret sauce to commercial printers that everyone in the Open source community would love to know.
rogerw
Post by rogerw » Mon Oct 28, 2013 10:12 pm
so letting the support layer cool and maybe adjusting the layer height so not pushed into support - yep that makes sense - thank you gents.
Post by roller » Wed Oct 30, 2013 6:41 am
rogerw wrote:so letting the support layer cool and maybe adjusting the layer height so not pushed into support - yep that makes sense - thank you gents.
Nophead, one of the more respected characters contributing to the reprap project guessed at the process here (after observing an Up) http://hydraraptor.blogspot.com.au/2012 ... pport.html
SeaweedCrisps
Post by SeaweedCrisps » Wed Nov 13, 2013 11:14 am
cheers for linking the article, x
http://www.myminifactory.com/ - free 3D file sharing platform
