Extrude problem clunk clunk clunk clunk
wayneuk
Re: Extrude problem clunk clunk clunk clunk
Post by wayneuk » Tue Jul 07, 2015 9:53 am
clunk clunk clunk! I carnt seem to shift it unless i use the up abs no clunking & works great... All the pla ive have tried including the expensive faberdashery uk pla it is no good even at various temps. I have tried the temp mod cooling mods.. It still clunks and fails awaiting my up pla today see if it does the same thing ..
Post by DrewPetitclerc » Thu Jul 09, 2015 4:22 pm
Post by roller » Wed Aug 19, 2015 1:23 pm
wayneuk wrote:clunk clunk clunk! I carnt seem to shift it unless i use the up abs no clunking & works great... All the pla ive have tried including the expensive faberdashery uk pla it is no good even at various temps. I have tried the temp mod cooling mods.. It still clunks and fails awaiting my up pla today see if it does the same thing ..
You have to be a lot more precise with your bed levelling with PLA and start the extruder a little bit higher than you would with ABS. You can get away with a few jams due to the nozzle being pressed hard against the bed with ABS but not with PLA. As soon as you jam for a second it will strip a little bit of PLA filament into a fine lubricating PLA dust that will make the extruder more prone to slipping later.
Glem3d
Post by Glem3d » Wed Mar 28, 2018 11:01 pm
Boa noite,
Execute o comando de withdraw e remova o filamento
Desligue a impressora
Desconecte o flat da cabeça da impressão
remova os dois parafusos que seguram o suporte de plastico que tem o cooler
remova a peça de plástico que vai em cima da engrenagem do motor
verifique se a canaleta onde passa o fio não está com desgaste, pois se estiver, o filamento não passa no local correto que é bem em cima da engrenagem de metal, causando o não tracionamento do filamento.
Também limpe com cuidado a engrenagem de metal que traciona o filamento.
Verifique se a mesma não esta solta. Isso aconteceu comigo. a engrenagem saia fora da posição.
Espero ter ajudado.
