In need of printer parts, help!!
jeeplvr
Post by jeeplvr » Thu Aug 08, 2013 8:17 am
Where can I get these shaft supports????
They are the little gray shaft supports in the picture.
scubamatt41
Re: In need of printer parts, help!!
Post by scubamatt41 » Thu Aug 08, 2013 8:37 am
http://www.thingiverse.com/thing:30893
When your mini is down and out because of the broken clip, try to fit it back and hold in place with a T-rap.
These clips should come with every new mini I think, otherwise ask PP3DP and they will ship them to you.
Where are you located?
jeeplvr
Post by jeeplvr » Thu Aug 08, 2013 9:35 am
Im in Reno Nevada USA.
These clips are as fragile as an egg shell. I was hopeing someone would know of a place to get them quickly like ebay or something.
Post by mr6k » Thu Aug 08, 2013 10:32 am
Hi jeeplvr,
I think Subamatt is suggesting that you make a temporary repair to the existing broken clip, then you can print some more for yourself.
scubamatt41
Post by scubamatt41 » Thu Aug 08, 2013 10:39 am
Yes, it was suggestion to temp fix the problem. Then you can hopefully print at least one clip. I also recommend that you contact PP3DP for original clips for future repairs. :)
Cheers
Post by mb20music » Thu Aug 08, 2013 3:12 pm
jeeplvr wrote:Im in Reno Nevada USA.
I can print a couple for you and mail them to you if you pay for shipping, probably around $6 for USPS Priority Mail which should take 2 days.
If I send them today (thursday) you should get it on saturday.
jeeplvr
Post by jeeplvr » Fri Aug 09, 2013 12:11 am
The zip ties worked for now. If I can find an stl file of the clips I will print some. Thanks for the responses.
Chris
Nevermind I found the files on thingiverse.
