Raft free printing on the MIini?
jeeplvr
Post by jeeplvr » Wed Aug 07, 2013 12:04 am
Can someone school me on raft free printing on the Mini?
I have searched and found nothing.
TIA
Re: Raft free printing on the MIini?
Post by mb20music » Thu Aug 08, 2013 3:53 pm
What do you want to know? it is pretty self-explanatory. When "NO RAFT" is selected in the Up Software, no raft is printed.
Post by DrewPetitclerc » Thu Aug 08, 2013 6:43 pm
Raft free is only going to be usable on a "glass" like surface, perf board is not good as you will tear up the bottom surface of your part.
Common sense. ;)
Post by wackojacko » Thu Aug 08, 2013 7:55 pm
Or use blue tape
Post by mr6k » Thu Aug 08, 2013 8:01 pm
I do all my raft free printing on an UP Plus using Kapton tape over the original plate. Not sure if this can be done with the mini. Am I right in thinking the mini comes with a perfboard base. Even so I would have thought Kapton tape could be stuck over it. Separating ABS from the Kapton is straightforward and does not rip up the bottom of the part. Indeed it forms an almost glass like finish to the base of the part. AND due to its reasonable adhesion to ABS it minimises any warping. (I have the original fixed "barrier" so cannot adjust the airflow, but with ABS it seems fine. Operating out of the UK in ambients of 16 - 32 degrees c !
Post by mb20music » Thu Aug 08, 2013 8:04 pm
I have been experimenting a little with lexan and have had decent results so far.
wilsonj
Post by wilsonj » Thu Aug 08, 2013 9:52 pm
mb20music wrote:I have been experimenting a little with lexan and have had decent results so far.
You might find over time parts become harder to remove, until they become one with the bed....
jeeplvr
Post by jeeplvr » Fri Aug 09, 2013 12:07 am
I must be doing something wrong. When I select raft free printing, the platform doesnt get close enough to the extruder and I get silly string.
Oral
Post by Oral » Mon Aug 12, 2013 2:46 pm
Raft free printing is hard for Mini. But i suggest you using mouse ears parts on your design. This will reduce your raft removal time on appropriate parts. The mouse ears should be placed under your model in a smart manner. You must cut off these ears with your pliers after printing. I think this is much more easy than removing whole raft.
br,
