Filament
Foreshadower
Filament
Post by Foreshadower » Fri Jul 05, 2013 2:54 pm
Hi everyone!
Does this filament work well with the Up!mini ?
http://www.3d2print.net/shop/product/abs-black-1-75mm/
If not, what would you recommend?
i know it would probably be better to use the Up brand, but the only store that sells it in my country is a bit pricey, so i'm trying to find an alternative.
scubamatt41
Re: Filament
Post by scubamatt41 » Fri Jul 05, 2013 7:44 pm
Hi Foreshadower, in which country are you located?
wilsonj
Re: Filament
Post by wilsonj » Fri Jul 05, 2013 10:03 pm
Looks like the same stuff I sell. If it is it will work, but support and raft will be very difficult to remove. You will want the wind barrier open at all times also.
Re: Filament
Post by roller » Sat Jul 06, 2013 12:07 am
Or do a temp mod (search the forums) and it will probably print nearly as well as regular ABS.
Foreshadower
Re: Filament
Post by Foreshadower » Sat Jul 06, 2013 11:06 am
scubamatt41 wrote:Hi Foreshadower, in which country are you located?
I'm from Portugal. The price I can get here for a 700g UP spool is 35€ plus shipping costs. Do you guys think its worth the money anyway or should I try to get other brand?
