routine maintenance list
ktronik
Post by ktronik » Tue Apr 15, 2014 1:29 am
Hey Guys and Girl
my printer is coming up to 12 months old, and does not print as good as it use to....
I am after people routine maintenance list, of things they do that makes a difference to their printing....
the main ones on my list are lubing the sliders and doing a level check and nozzle height check, but what other things have others found work good for them??
thx for you help
Kerry
D3rax
Re: routine maintenance list
Post by D3rax » Tue Apr 15, 2014 7:27 am
Clean the nozzle from time to time. I remove the nozzle, heat it up with a butane torch and dip it in alcohol a few times.
By the way, bed level en nozzle height check is something you should do regularly, especially when you get lift.
Up! Plus
DickL
Post by DickL » Tue Apr 15, 2014 12:20 pm
Does anyone have a good way to lube the sliders?
DickL
ming
lubrication
Post by ming » Wed Apr 16, 2014 4:47 am
I prefer thick oil over grease
I use a syringe with a 1.5" long plastic tip. I work in medical devicefield so ido have access to small syringes n tips.
A few drops is all it needs
Dream@night / Holdit@sameday
Post by roller » Wed Apr 16, 2014 7:32 am
I think Bruce recommended lithium grease when I had a dry patch on my Mini linear rails. I prefer teflon spray on all my printers and CNCs. It doesn't adhere dust which then becomes an abrasive, it's easy to apply and it's very slippery :)
ktronik
Post by ktronik » Fri Apr 25, 2014 6:53 am
thx everyone....;)
