Taulman 618-1.75mm Co-Polymer
amd-tec
Post by amd-tec » Tue Dec 11, 2012 7:39 am
Waiting is over ;).
Taulman’s 618-1.75mm Co-Polymer available for Pre-Order.
www.taulman3d.com
http://www.amd-tec.com
juancr
Re: Taulman 618-1.75mm Co-Polymer
Post by juancr » Tue Dec 11, 2012 9:18 am
I will order it next month :mrgreen:
Regards,
JuanCR
walter
Post by walter » Tue Dec 25, 2012 1:01 pm
Now shipping, mine just arrived. I've only done a couple of prints, but so far It has worked really well in my Afinia/Up Plus (mine has the pen clip extruder / air cooling mod).
amd-tec
Post by amd-tec » Tue Dec 25, 2012 1:32 pm
walter wrote:Now shipping, mine just arrived. I've only done a couple of prints, but so far It has worked really well in my Afinia/Up Plus (mine has the pen clip extruder / air cooling mod).
Congrats! Any pics available?
twocycler
Post by twocycler » Tue Dec 25, 2012 5:05 pm
I have been testing the Taulman 618 nylon on my Up! Mini. It prints really cleanly and the luster and detail is in some cases better than the oem abs. I have experimented a bit with extruder temp. I started with stock (260-270C) temp and the material was incredibly strong, but extremely hard to separate a raft or support material from it. I went down to -30C and it extruded very pretty with great detail, and the raft would come away cleanly and easily, but when I flexed it really hard it would crack and delaminate. Now I am at -15C and its strong, but the raft is still too tough to remove. I am next going to test -20C which is where I think the best setting will be.
This stuff at the right temp is crazy strong and its luster reminds me of a Stratasys natural part.
bashidap
Post by bashidap » Wed Dec 26, 2012 7:36 am
Changing temperature on an UP?? How do you do that? The only option I know of is choosing ABS or PLA.
amd-tec
Post by amd-tec » Wed Dec 26, 2012 7:40 am
The temp control for Up! ------> How many different way to do it?
Hope Nylon material would be added to software setup ;).
Post by mr6k » Wed Dec 26, 2012 12:43 pm
Looks like an interesting material but at US$47 to post to UK it would be an expensive experiment. Anyone know if there is, or is likely to be a a UK distributor?
twocycler
Post by twocycler » Wed Dec 26, 2012 5:38 pm
Sorry if I did not make this clear, but I have been altering the resistance reading from the hot end to the controller board. For roughly every 1 ohm of increased resistance, the actual extruder temp drops 3C. From my prints it looks like the best setting for the Taulman nylon is to add 8 ohms of resistance, which lowers the extruder temp by approximately 24C.
Post by roller » Wed Dec 26, 2012 11:54 pm
Just to be pedantic - 8ohms will reduce it a fraction under 22degrees i.e. approx 2.7 ohms/degree seems to be a more accurate assessment based on the work of others. I've not yet tried such shenanigans myself :)
twocycler
Post by twocycler » Thu Dec 27, 2012 1:19 am
roller wrote:Just to be pedantic - 8ohms will reduce it a fraction under 22degrees i.e. approx 2.7 ohms/degree seems to be a more accurate assessment based on the work of others. I've not yet tried such shenanigans myself :)
Did you notice where I said 'approximately''? BTW, not to be pedantic or pompous, but Id like to point out in your post above that you say '2.7ohms/degree'. You clearly have reversed your ratio as it would more correctly be 2.732919254658385093167701863354 degrees celsius per ohm, and not 2.7 ohms per degree. Happy holidays! 8-)
Post by roller » Thu Dec 27, 2012 3:08 am
Indeed, it is back to front, conversely and counter-rotated - I mean about 2.7degrees/ohm. I wasn't picking on your numbers by the way (I didn't even verify them) I was actually giving the figures from the lookup table for the temperature probe. I thought others might find it useful to have the more accurate figure although using the lookup table directly probably gives the best results. I rounded from 2.696something.
DytHlt
Post by DytHlt » Thu Dec 27, 2012 3:53 am
^ :roll:
Anyways... I just ordered some of this stuff, excited to try it out. :)
Wouldn't Nylon be more "food safe" than PLA? I'm curious.
Post by roller » Thu Dec 27, 2012 2:04 pm
DytHlt wrote:^ :roll:
You'd have to ask Taulman as it depends on the specific formula of his Nylon filament. Nylon can be both food safe and horribly toxic due to additives.
DytHlt
Post by DytHlt » Thu Dec 27, 2012 10:20 pm
Good to know.
wilsonj
Post by wilsonj » Fri Dec 28, 2012 12:32 am
618 is "inert" to the body, but its not FDA approved, as certification costs too much.
There will be a medical grade nylon called 680 released in the future (could be a year or two away). It also won't be FDA approved, however it will be allowed in the body as a surgical insertion.
Bottom line. Its not approved for food use.
juancr
Post by juancr » Sat Jan 19, 2013 2:16 am
Some print examples courtesy of amd-tec: http://d3print.blogspot.com.es/
Regards,
JuanCR
jmorro
Post by jmorro » Wed Feb 27, 2013 10:08 pm
Afinia and UP! 3D printer users that want to print with the Taulman 618 nylon filament can purchase the Extruder Nozzle Temperature Switch for Afinia and UP! 3D Printers from Octave Systems. This enhancement to the Afinia and UP! 3D Printers reduces the nozzle temperature approximately 30 degrees C. Works great. You can purchase a Bundle that includes the 618 nylon, the temperature switch and a Garolite LE printing plate, which is preferred for printing with nylon.
Nevil_Clavain
Post by Nevil_Clavain » Tue Mar 05, 2013 4:08 pm
Glad you guys are trying this out. I've been thinking that printing Nylon would be cool. My concern has been how to clean the nozzle/extruder if it gets clogged. I don't think Nylon dissolves in Acetone.
Post by JuliaDee » Thu Mar 07, 2013 10:27 pm
Nevil_Clavain wrote:Glad you guys are trying this out. I've been thinking that printing Nylon would be cool. My concern has been how to clean the nozzle/extruder if it gets clogged. I don't think Nylon dissolves in Acetone.
IYes, I was concerned about that as well, but I've been printing with nylon for a few weeks now, and have gone back and forth between nylon and ABS a few times using the same nozzle. So far (knock on wood) no clogging issues. Since Nylon has a lower melting point than the Up's ABS setting, I think it gets pretty well flushed out by extruding material at the higher temp.
julia
