Sticky print boards for sale
Anything you like to buy, sell, offer, or hire from the fellow Uppers?
scubamatt41
Post by scubamatt41 » Sat Apr 26, 2014 11:35 am
Still no website but still no problem selling these amazing boards to print on.
Not for raftless printing!! Will fit UP org and UP2
20140426_131054 (Small).jpg (115.32 KiB) Viewed 7720 times
20140426_131205 (Small).jpg (99.41 KiB) Viewed 7720 times
D3rax
Re: Sticky print boards for sale
Post by D3rax » Sat Apr 26, 2014 6:47 pm
Whats the price on these?
Up! Plus
scubamatt41
Post by scubamatt41 » Sat Apr 26, 2014 8:38 pm
D3rax wrote:Whats the price on these?
Hi D3rax,
Price on these is € 9.- a piece
Cheers
D3rax
Post by D3rax » Mon Apr 28, 2014 7:29 am
I might be interested. Is the "sticky" imprint on both sides? And which materials do stick without raft?
Up! Plus
scubamatt41
Post by scubamatt41 » Mon Apr 28, 2014 9:47 am
D3rax wrote:I might be interested. Is the "sticky" imprint on both sides? And which materials do stick without raft?
The Sticky imprint is on oneside and on the shiny side of the board which is the sunny side UP so to speak.
The imprint is there to give a little bit more tac when printing on the UP mini. The headbed of the mini goes up to 50 degC only as standard. I moved from selling 4mm for the UP mini and will make that 3mm max. Unless you have made a modification to get higher temps.
For raftless printing I sell the Vlacky (vlakkie trans in Dutch) which is € 5.- a piece. It comes without imprint, apart from the type name in the bottom left corner :-) You can ofcourse print with raft on that board. Printing with excotic filaments are no problem even on a non heatbed. So far, apart from ABS and PLA, I have printed with NYLON, LAYWOOD and third party filament.
Between you and me, I moved back to using the org pp3dp filament only. The UP machines are not temp controllable and the org filament is available at my doorstep now. I don't want to make mods to the printer. Besides it's printing for 18 months without any mod just fine, only a broken axel clip but that was me own bad. Combined with the software upgrades from pp3dp the org filament gives me the best possible outcome every time. That filament seems to be more resistant to moisture as well.
Cheers with Ears
