Small nuts and bolts
Posted: Sun May 12, 2013 5:29 am
by Lawrence
Hi all
A few days ago some one on the forum asked about small nuts and bolts.
So, here are a few:
Small bolts2.jpg (139.27 KiB) Viewed 11788 times
From the left, the 1st is a purchased 3mm diameter nylon nut and bolt. Next is a printed 2.75mm diameter set, then a 2.5mm set and on the right is a 2.25mm set. All nuts do screw on to the bolt securely. The images are taken with the raft removed but no clean up of the models done.
To show the sizes of the three printed sets I have added them with the measurement caliper which unfortunately the camera could not capture the reading which was 2.25mm.
The ruler measurement gives some idea of sizes:
Small bolts.jpg (90.85 KiB) Viewed 11788 times
So, in answer to the query about the Up!Plus having the ability to print small nuts and bolts, it's a definite YES!
Lawrence
Re: Small nuts and bolts
Posted: Sun May 12, 2013 2:29 pm
by roller
You're nuts...
and bolts too i guess
Posted: Sun May 12, 2013 3:26 pm
by scubamatt41
Yeah, Lawence is Bolts ;) and really small nuts :lol:
Posted: Mon May 13, 2013 7:05 am
by Lawrence
Hi again
... even smaller now. Today I printed the same nut and bolt, but this time with a 2.00mm diameter. So, yes, the Up! will successfully print useable M2 nuts and bolts.
I won't bother uploading a photo. Just look at the previous ones that I posted, then step back further from your monitor until they look smaller. That is what the M2 nut and bolt look like.
I must bolt now.
Lawrence
Posted: Mon May 13, 2013 7:07 am
by roller
They are very impressive. Have you just used a thingiverse type source or did you draw these up yourself?
Posted: Mon May 13, 2013 7:11 am
by Lawrence
Hi Matt
I downloaded some nuts and bolts from Thingiverse, then imported the ones I wanted use into Google Sketchup, where I modified the bolt head to a knurled circle and added a groove for a screw driver, then converted it back to STL format. The rest is history.
Lawrence
Posted: Mon May 13, 2013 2:31 pm
by scubamatt41
Nice work Lawrence :)
Posted: Tue May 14, 2013 4:20 am
by josejuako
Yes Lawrence , very nice work .
Posted: Thu May 16, 2013 11:33 am
by outsider
Lawrence,
What print settings did you use to print those nuts and bolts?
What was the material?
Posted: Thu May 16, 2013 11:51 am
by Lawrence
Hi
all explained here: http://www.pp3dp.com/forum/viewtopic.ph ... =60#p16834
Lawrence
