Finger press engine
DickL
Finger press engine
Post by DickL » Fri Nov 01, 2013 2:49 pm
Hi
I'm using TurboCAD as my design program. It is the most difficult software I have ever tried to use. I was not getting anywhere until I found the mechanical tutorial by textualcreations. It take you keystroke by keystroke through the entry of the finger press engine. After I entered the engine, I naturally, printed it. I made some mods and printed it again. All the parts except the screws were made on my printer.
I cannot recommend TurboCAD to anyone. I only have it because I found a web site that sells older versions at a very good price.
Textual creations web site http://www.textualcreations.ca
DickL
DickL
Re: Finger press engine
Post by DickL » Fri Nov 01, 2013 2:52 pm
Hi
I'll see if I can get the picture file smaller.
DickL
DickL
Post by DickL » Fri Nov 01, 2013 3:00 pm
Finger press engine resize.jpg (183.5 KiB) Viewed 7763 times
josejuako
Post by josejuako » Fri Nov 01, 2013 10:33 pm
Nice print , I use Solidworks , but I like more Rhinoceros .
Jose
Post by JuliaDee » Sat Nov 02, 2013 12:07 am
I agree, TurboCAD is user-hostile. I haven't had much better luck with ViaCAD either.
Post by DrewPetitclerc » Sat Nov 02, 2013 6:47 am
I use SolidWorks 2012 since I pretty much do mechanical engineering and my day job supplies it.
Every model is water tight with no issues through the printer.
Drew
gloga1
Post by gloga1 » Wed Nov 06, 2013 7:16 am
Use Autodesk Inventor works well has a special 3d print output with fine tuning adjustments
