Raftless
LonV
Raftless
Post by LonV » Thu Nov 15, 2012 11:58 pm
Hey all,
I've been experimenting with raftless and I can get decent results, except for the fact that the software appears to print 1 fine layer of raft. This layer is basically impossible to remove. :)
Any ideas? I'm using the 1.18 beta.
-Lon
LonV
Re: Raftless
Post by LonV » Fri Nov 16, 2012 1:03 am
Hmm...maybe I was drunk the last time I tried this. I swear it was printing a layer of raft...now it is truly raftless. Hmm, maybe I was using 1.17 before and I just thought I was using 1.18. :D
wilsonj
Re: Raftless
Post by wilsonj » Fri Nov 16, 2012 4:16 am
The beta version of 1.17 did this.
LonV
Re: Raftless
Post by LonV » Sun Nov 18, 2012 9:16 pm
Yay! I knew I wasn't crazy. I just printed an object (raftless) in the 1.18 beta and it printed a single, thin layer of raft slightly (1mm?) larger than my model. It may be a combination of settings I'm using that's triggering this...but it does still happen. I'll do some experimenting later to see if I can figure out what triggers this.
vindicarblack
Re: Raftless
Post by vindicarblack » Sat May 03, 2014 2:45 am
I have the same issue - I make sure the model is at "0" z height, and "no raft" is selected, but no matter what i do i always get a one layer raft - really frustrating. Is there some pro trick I'm missing?
outsider
Re: Raftless
Post by outsider » Wed Jan 28, 2015 7:48 pm
Post some pictures of this draft layer.
I've never had this happen to me.
adrian.
My Blog
Re: Raftless
Post by DrewPetitclerc » Fri Jan 30, 2015 9:05 pm
Did you update the ROM files when you began using the new software versions?
My work "UP! Plus" are using:
software 2.13
ROM V6.070
Firmware V3.05
Drew
