The raft is really hard to remove after update
RustyBoy
Post by RustyBoy » Thu Oct 11, 2012 1:11 am
Anyone find the raft becoming hard to remove after the latest update(1.17 software with 6.041 rom)?
I've used to print spring with my UP! with no problem. The support and raft can be ripped off without breaking the model. However , it is completely different in the new update.
I've tried uninstalling 1.17 and gone back to 1.16 , but the problem still there.
Can anyone help? Thank you
Re: The raft is really hard to remove after update
Post by wackojacko » Thu Oct 11, 2012 1:32 am
Do you have the v11 wind barrier with the door open, its under the example folder on v1.17
www.3DPrintingSystems.com
juancr
Post by juancr » Thu Oct 11, 2012 2:19 am
I have that problem when printing 0.15mm layers and forguet to open the wind barrier.
Regards,
JuanCR
RustyBoy
Post by RustyBoy » Thu Oct 11, 2012 2:47 am
wackojacko wrote:Do you have the v11 wind barrier with the door open, its under the example folder on v1.17
Thank you
I'm currently using the v10 wind barrier. Do v11 with the door open makes a big difference?
walter
Post by walter » Thu Oct 11, 2012 3:43 am
You might also check to see if your print settings got reset with the update. If your Print->Support->Dense setting is large, you could try reducing it to 2 layers. I'm not sure which of the other settings may affect support material removal.
Post by wackojacko » Thu Oct 11, 2012 10:14 am
Yes door open if support material is hard to remove
Tiertime-Edward
Post by Tiertime-Edward » Sat Oct 27, 2012 1:38 am
Hi All, the reft will be easy to remove in UP! software v1.18.
Please stay tuned to the blog and forum.
Post by wackojacko » Sat Oct 27, 2012 4:18 am
Wow the v18 raft removal is like peeling away! Well done Edward and team.
Post by roller » Sat Oct 27, 2012 12:25 pm
Bruce, any comment on what it's like with 3rd party filament and rafts if you've tried any?
Post by JuliaDee » Sun Oct 28, 2012 1:23 pm
Actually I've found raft removal to be really easy using 1.17. But I'll give 1.18 a try...
julia
