ABS Adhesion Solved with a hair dryer....
futurefab
Post by futurefab » Fri May 04, 2018 1:41 pm
Finally got ABS to perform reliably. Here's how. Hope it helps someone. Does anyone else do this?
https://youtu.be/nKDMc05lpPs
brunningm
Re: ABS Adhesion Solved with a hair dryer....
Post by brunningm » Mon May 07, 2018 10:22 am
Hey, had a watch.
I don't print ABS much, but I've never needed extra heat on the upbox+. Possibly the Upmini just doesn't have the voltage to heat the bed and the chamber quickly or maintain it. Never used it so I won't weigh in =0
One thing I noted on the video is the four parts at the end which had their rafts overlapping. If you merge the models before printing, you get a single raft designed as if it were one object, and it might help with the clicking a little.
