Where is the bed movement? UP+
moreupper
Post by moreupper » Fri Oct 13, 2017 9:19 am
Some time ago when using the old software (using UP+), there was a option to move the the bed around. Now this option is missing?
I was using it when making nozzle adjust. Move center, and all the corners.
Where is it?
Re: Where is the bed movement? UP+
Post by Owen Sparks aka Marksman » Fri Oct 13, 2017 10:16 am
Calibration page, icon with two rulers on it.
moreupper
Post by moreupper » Fri Oct 13, 2017 2:54 pm
Still not find it.
I attach two pic.
old-up is my old windows app where i can move the bed around. It is the FL-FR-NL-NR-Center i looking for.
new-up is where i cant find it.
brunningm
Post by brunningm » Sat Oct 14, 2017 7:30 am
moreupper wrote:Still not find it.
I attach two pic.
Where it says Nozzle Height, there is a box you can put numbers in. If you click Set, it will change the saved nozzle height, but if you click move, it will just raise or lower the bed to that height instead.
Post by Owen Sparks aka Marksman » Mon Oct 16, 2017 6:50 am
I believe you can click on the locations (the numbers 1-9) to move in x/y
moreupper
Post by moreupper » Sun Oct 22, 2017 7:39 pm
None there have missed it?
The only reason to use the new and real bad software compared to the 2.18 is the support for other filament temperature!
I really miss the old 2.18 development. There is no logic in putting so much time in so bad software. If you really want to spend time on development, do it on a new firmware there can handle standard G-CODE, so we can decide to use another slicer software as ex. S3D.
I know there are G-Code board for the up+, but i don't want to pay more money on this.
JAAI
Post by JAAI » Sun Oct 22, 2017 8:52 pm
I also support the continuity of the software up 2.18, you only need the temperature control, the power to choose the fill amount (100% / 99%). I liked the other one much better, so a +1 for that request on my part!
