Nozzle problem UP2 Plus
Robin
Post by Robin » Wed Aug 31, 2016 11:35 am
Printer stopped on a nozzle temperature fault. I wobbled the wire and saw sparks.
I'd guess the element has boiled the tin out of the solder, arced and burnt the wire to a crispy carbon residue.
The printer is only 4 months old, bought it from Maplins, 9th may 2016
I have worked it hard, but what to do now?
ricks01
Re: Nozzle problem UP2 Plus
Post by ricks01 » Wed Aug 31, 2016 1:27 pm
It is covered under your 12 month warranty, contact place of purchase for more info.
Robin
Post by Robin » Wed Aug 31, 2016 2:23 pm
Maplins wanted to swap the whole machine but I cannot be bothered to repack it so they are trying for a part. Their technician will call me back within 48hrs.
I also ordered, "New Thermocouple 24V 80W Cartridge Sensor Heating for UP 3D Printer Print Head" from that auction site. They cannot tell a thermocouple from a thermistor, no dimensions given and Economy shipping from China is 2-3 weeks away. The assembly looks to be a loose fit with Loctite, so I am presuming I can separate it with a bench press?
Is 24V 80W correct?
ricks01
Post by ricks01 » Wed Aug 31, 2016 2:59 pm
yes the UP nozzle heater uses a 24 volt, 80 watt cartridge heater.
Is this what you purchased?
http://www.ebay.com/itm/New-Thermocoupl ... SwLpdW85Ek
Robin
Post by Robin » Wed Aug 31, 2016 3:23 pm
That's the one. Is it safe? If you tell me no then I will bin it :mrgreen:
Liova
Post by Liova » Wed Aug 31, 2016 3:26 pm
It is not glue, just thermal paste.
Robin
Post by Robin » Wed Sep 07, 2016 9:28 am
Still no phone back from Maplin technical support :roll:
Parts have started arriving from my ebay foraging expedition. Still some way off an actual element, but the high temperature heat transfer guck has arrived and some copper crimps.
I have reattached the wire by crimp and it works. Slight worry about everything shorting out if another wire breaks but new elements are in the post and I am back in production.
Robin
Post by Robin » Wed Sep 07, 2016 2:37 pm
Of course 10 seconds after that the new element and thermistor pair arrive... :roll:
Robin
Post by Robin » Mon Sep 12, 2016 1:43 pm
Looks like this ebay UP! print head has grub screws to hold the heater and thermistor.
If this works I think I will buy a couple more, I could change heaters with even waiting for it to cool.
