Printing Soft Spot
Irregular
Printing Soft Spot
Post by Irregular » Tue Aug 11, 2015 1:46 pm
Hello everyone!
I wish I had more to contribute to this community then just looking for help. In time I hope I can return the favors.
I have a H480 and its the printing is bad on once side. I am not sure what is causing it. Perhaps a skip in the plate or something? I have manually calibrated and leveled the machine a few times. The same print on my h479 does not have this problem.
The photos are taken 180' from each other. Any ideas on the problem?
As always thanks. If your answer is local to MD I owe you a case of beer!
Good print
Good print.jpg (44.85 KiB) Viewed 2805 times
Bad Print
bad print.jpg (48.75 KiB) Viewed 2805 times
Irregular
Re: Printing Soft Spot
Post by Irregular » Wed Aug 12, 2015 3:44 am
OK, I get to post a reply to my own question.
It seem as the belt grip was loose, and the metal spring clip was in the wrong spot. I had to go in and tighten a few things up, and it is printing better. Not as perfect as my other printer yet, but i am dialing in the issues. I hope this helps someone!
