Plastic part that holds the extruder.
stormychel
Post by stormychel » Thu Oct 16, 2014 10:22 pm
Does anyone know if this should be included in spare parts? I mean the main block that holds everything in place, and has the electronics / connectors on top of it...
Also, the small part from the feeder assembly which pushes the bearing in place, is that available?
Thanks in advance :)
@stormychel
mb20music
Re: Plastic part that holds the extruder.
Post by mb20music » Fri Oct 17, 2014 3:37 am
Is this what you are looking for here?
http://www.thingiverse.com/thing:128630
Post by roller » Fri Oct 17, 2014 5:21 am
All parts should be there except the inner feed block which holds the pressure bearing - this is made from another plastic and so is not intended to be reprinted.
If you can't find the part you want try downloanding earlier versions of the software. They curate some older parts from the spares and sometimes they seem even to remove parts still in use on current printers.
stormychel
Post by stormychel » Fri Oct 17, 2014 6:22 am
Ok thanks! Was thinking of moving that pressure plate to allow air to pass through it to add more cooling of the stepper
@stormychel
