Printing a void with no support for part insert using pause
Mrdaved
Post by Mrdaved » Mon Apr 14, 2014 4:57 pm
I want to print parts that have inserted nuts or bolt heads. I want to pause at a certain height and insert nut. This requires printing the void with no support. Can this be done on my Afinia?
D3rax
Re: Printing a void with no support for part insert using pa
Post by D3rax » Tue Apr 15, 2014 7:37 am
Yes, turning support off (in printsettings set support to base only). Or you can rotate your part in a way so that the spacing of the nut does not need support.
Up! Plus
Mrdaved
Post by Mrdaved » Tue Apr 15, 2014 6:32 pm
I do not see the base only setting. Where is it?
D3rax
Post by D3rax » Wed Apr 16, 2014 1:26 pm
Do you have the latest version of the PC software? Don't know if this options is yet available on the MAC version. You can find this option under printsettings.
Up! Plus
Post by JuliaDee » Thu Apr 17, 2014 3:52 am
Mrdaved wrote:I do not see the base only setting. Where is it?
It's in the pulldown for minimum support area.
