trying to print this...help!
mec949
Post by mec949 » Fri Mar 14, 2014 10:41 am
I'm trying to print this voronoi bracelet. The print came out OK but the support material is stronger than the bracelet. In trying to remove the ssupport , the bracelet was ruined. The bracelet is here: http://www.thingiverse.com/thing:88849
Can you print this without support at all? Thanks for any help. M
Re: trying to print this...help!
Post by DrewPetitclerc » Fri Mar 14, 2014 4:27 pm
Yes you can, try these settings.
mec949
Post by mec949 » Fri Mar 14, 2014 11:54 pm
Thank you for your response. I'm still playing with settings.
I tried what you suggested and unfortunately the voronoi structure was compromised and the print was stopped.
Disappointing really that these structures are so difficult to print on an up...
Post by mb20music » Sat Mar 15, 2014 12:16 am
I printed this voronoi style bear (without support) and it turned out great. i don't see why the bracelet wouldn't work. I will try to print it and will let you know how it goes.
http://www.thingiverse.com/thing:150431
mec949
Post by mec949 » Sat Mar 15, 2014 12:35 am
Thanks. Maybe I'm doing something wrong
Post by roller » Sat Mar 15, 2014 1:20 am
mec949 wrote:Thanks. Maybe I'm doing something wrong
Not necessarily ... it has a lot to do with the angles and rate of change that happens to be present. Voronis (and other complex organic patterns) are tedious to review the rate of overhang by eye. If you don't mind experimenting and using up your filament then try flipping it upside down - it might be more print friendly.
I have printed voroni and other dense cell structures before with using support and had no troubles. You might want to make your support more sparse. You also might have issues if you are printing the filament too hot (ie aftermarket filament without a temp mod) - printing with the wind barrier open may help a bit either way.
mec949
Post by mec949 » Sat Mar 15, 2014 1:50 am
Thank you this is very helpful, and I'm still learning the ropes with my up.
How do you print the support material :
Less densely
More sparse (less actual support especially for voronoi)
What settings do I use?
Thank you again
mec949
Post by mec949 » Sat Mar 15, 2014 8:06 am
Just tried to print with the advice given here and it failed again. Might put this in the impossible basket for the up.
Could try it one more time but not sure it is worth it.
If anyone here prints it, I'd love to see the results.
One comment though, on one side of the bracelet, there is a tight cell structure that is close enough spans that front need support, and is quite strong. If the whole bracelet was like that it would work a charm
