Platform Height settings
joeb
Post by joeb » Fri Dec 20, 2013 7:01 pm
Just changed the nozzle height and forgot to click set bottom
Platform now goes to the bottom and continues to drive past with the belt constantly slipping (clicking noise
Cant seem to stop it tried clicking go to bottom button, reset initialise, platform calibration
every option available evebn tried the windows fix of turning it off and on
Help anyone
Cheers
Joe
Christina
Re: Platform Height settings
Post by Christina » Fri Dec 20, 2013 7:17 pm
Even unplugging all the connections + power, then re-connecting & turning it back on, then re-initializing? I've had lots of wacky things happen (all my fault I think) but I've managed to always get it working again. Have you re-initialized using the button on the front of the machine or in the maintenance window?
joeb
Post by joeb » Fri Dec 20, 2013 10:37 pm
I've turned it off, reinitialised it, reflashed the ROM, manually lifted the platform up whilst running so that it can travel the full height back down, pulled the plug out, stood on my head and done everthing again
I am at a loss as to the next step other than return for repair???
Cheers
Joe
Christina
Post by Christina » Fri Dec 20, 2013 10:56 pm
Don't know what to say...try taking out the SD card and then reinserting...have you asked support? I'm surprised no one has chimed in yet.
Astro
Post by Astro » Fri Dec 20, 2013 10:59 pm
Sounds like a hardware problem. I would be looking to see if my limit switches are working.
Post by JuliaDee » Sat Dec 21, 2013 12:08 am
Sounds like a limit switch is not working - either not engaging mechanically or maybe a connector pulled out?
joeb
Post by joeb » Sun Dec 22, 2013 10:02 pm
was thinking software as it occurred when I was doing a platform height adjustment and failed to click go to bottom button which is the final part of the process
will have a look at the limit switch as well
Joe
