Octave Enclosure
Re: Octave Enclosure
Post by JuliaDee » Sun Jan 05, 2014 2:34 pm
hajime wrote:Hi Julie,
After using it for awhile, do you still think it is good to have the Octave Enclosure?
Yes, it reduces warp and improves print quality for me.
hajime
Post by hajime » Tue Jan 07, 2014 2:28 am
Thanks for sharing. Which temperature setting device from Octave are you using?
Post by JuliaDee » Tue Jan 07, 2014 2:33 am
Not from Octave - the one that I designed and built myself:
http://www.pp3dp.com/forum/viewtopic.php?f=28&t=22170
hearbob
Post by hearbob » Wed Jan 08, 2014 10:00 am
I've had the Octave enclosure for a few months now and couldn't be happier. For me it helps reduce the fumes from printing and also maintains an even temp around the build platform. The last few days we've been -10 to -15 and still printing. These are shots of it. I have mad a couple of mods. Temp controller on the printer, filament holder and guide. Also relocated the power switch on the printer to the front and added a power switch to the enclosure. Not pictured here is the Ord Bot printer I am building.
Detail of new filament guide. Part of this was derived from a Thingiverse upload of JuliaDee's
Inside with figure made from a Kinect scan
My enclosure,
incipienta
Post by incipienta » Wed Jan 08, 2014 3:17 pm
The filament "roller skates" are interesting; how do you like them?
...and are the STLs public?
Post by JuliaDee » Wed Jan 08, 2014 3:37 pm
incipienta wrote:The filament "roller skates" are interesting; how do you like them?
I do like "spool rollers" for their simplicity and ease of spool changes, but apart from the obvious limitations on spool width, if they're not a simple flat roller they also have difficulty with spools that are completely full, since the filament binds/drags on the inner part of the roller instead of just the spool edge riding in the center of the roller.
Post by DrewPetitclerc » Wed Jan 08, 2014 4:55 pm
incipienta wrote:...and are the STLs public?
Can be found here:
http://www.thingiverse.com/make:24259
Drew
hajime
Post by hajime » Thu Jan 09, 2014 12:27 pm
hearbob wrote:I've had the Octave enclosure for a few months now and couldn't be happier. For me it helps reduce the fumes from printing and also maintains an even temp around the build platform. The last few days we've been -10 to -15 and still printing. These are shots of it. I have mad a couple of mods. Temp controller on the printer, filament holder and guide. Also relocated the power switch on the printer to the front and added a power switch to the enclosure. Not pictured here is the Ord Bot printer I am building.
What are the advantages of having an enclosure for the filament roll?
ikumajp
Post by ikumajp » Thu Jan 09, 2014 12:50 pm
Dry filament means less popping equal less artifact, it helps to keep your print cleaner,
More about it here:
http://hackalizer.com/for-the-best-3d-p ... ament-dry/
I made a few cheap DIY filament container too, mine is less pro though...
http://www.thingiverse.com/thing:211024
adamj12b
Post by adamj12b » Mon Jan 13, 2014 12:19 am
hearbob,
I like the filament guide you created. Are the files for it available anywhere?
-Adam
albill
Post by albill » Tue Jan 14, 2014 7:30 pm
I just got an Octave enclosure. Can you share the STL files for your filament guide? None of the ones that I have work.
hajime
Post by hajime » Wed Jan 15, 2014 3:11 am
Thanks Julie and ikumajp.
hearbob
Post by hearbob » Thu Jan 16, 2014 1:29 pm
hi, Sorry been busy with my day job teaching color theory. Will post my stl filament guide tonight when i get home for those interested.
hearbob
Post by hearbob » Fri Jan 17, 2014 10:25 pm
Hi I posted the stl for my guide in Thingiverse http://www.thingiverse.com/thing:228610, it's listed as a remix of Julia's "Filament guide for UP! with integrated Filament Cleaner,http://www.thingiverse.com/thing:26710. A most excellent accessory. It is the filament cleaner I attached to my filament guide (mine is a rather simple guide) as I found the one that came with the enclosure horrible. Sorry for any delay this was the first week the college I teach at was back in session and as I also over see all of the department digital labs I've been busy.
