filament storage
rvalle
filament storage
Post by rvalle » Tue Dec 10, 2013 5:06 pm
Hi!
I have ordered a few different ABS filaments to test colours/transparent.
How should they be stored so that they keep their quality?
Also, they are not original UP! ABS, but "seems" to work on the UP!. What would you say is a good "test" print to check it works OK?
R.
Re: filament storage
Post by roller » Wed Dec 11, 2013 5:46 am
So the moisture doesn't get to them. I use an airtight drum and the bottom 10cm is filled with kitty litter to absorb moisture. Others keep them on or near the water heater. Whatever you can do to keep it dry and if not dry warm to keep the relative humidity low.
motoyoyo
Post by motoyoyo » Fri Dec 13, 2013 2:54 am
I use a Foodsaver vacuum sealer.
rvalle
filament storage
Post by rvalle » Fri Dec 13, 2013 8:22 pm
Thanks for the replies.
Got a plastic container with decent sealing and added some silica gel bags...
Will see how it goes.
Sent from my iPad using Tapatalk
