Video of PVA Dissolvable Support
Post by JuliaDee » Mon Sep 30, 2013 4:13 pm
A lot of people talk about their dual extruder setups being able to do PVA dissolvable support but there aren't a whole lot of videos around of it actually being done AFAIK.
Here's the Zim printing a ball in a cage:
http://vimeo.com/75748504
I don't know why they've printed a big solid box around it and have asked. It's also not clear how much time it takes to dissolve all that support (looks like they used more than was really needed for the ball) and I've asked them that as well.
cordawg92
Re: Video of PVA Dissolvable Support
Post by cordawg92 » Mon Sep 30, 2013 5:18 pm
I'm assuming that the walls around the model were printed to prevent drafts.
amd-tec
Post by amd-tec » Mon Sep 30, 2013 6:34 pm
First good video I have seen.
The box for cleaning the PVA nozzle?
http://www.amd-tec.com
Post by JuliaDee » Mon Sep 30, 2013 9:37 pm
amd-tec wrote:First good video I have seen.
Your guess is correct - the skirt is for wiping the PVA nozzle. They're working on a software solution that won't require a skirt.
It took 5 hours in warm water to dissolve the support in this demo part.
LonV
Post by LonV » Tue Oct 01, 2013 3:54 am
The print quality of the cube itself doesn't look very good.
Post by JuliaDee » Tue Oct 01, 2013 3:58 am
LonV wrote:The print quality of the cube itself doesn't look very good.
True, hard to say why or what settings they used for this print. The excellent basic print quality of the printer has been established:
http://www.kickstarter.com/projects/141 ... afdf498885
Lann
Post by Lann » Tue Oct 01, 2013 5:38 am
Nice. Makerbot is also promoting its dissolvable filament.
http://www.makerbot.com/blog/2013/09/30 ... s-melting/
Price at $65, it 'dissolves in limonene, a common, colorless, citrus-scented solvent available online and in grocery and home stores. Just immerse your print in a limonene bath and, depending on the size and geometry of your object, MakerBot Dissolvable Filament will melt away in just 8-24 hours.'
Now, hoping for a larger up plus with dual extruder and PVA filament from pp3dp.....
LonV
Post by LonV » Tue Oct 01, 2013 6:08 am
Yeah, it makes me wonder if switching the head is causing a problem. But they're priming the crap out of it with that outer wall, so I'm not sure why that would be a problem.
amd-tec
Post by amd-tec » Tue Oct 01, 2013 7:50 am
I`ll bet it`s printed with draft settings..., I might be wrong, but anyway.
amd-tec
Post by amd-tec » Tue Oct 01, 2013 7:52 am
Lann wrote:Nice. Makerbot is also promoting its dissolvable filament.
And again, where is the video?
Post by wackojacko » Tue Oct 01, 2013 6:17 pm
This dissolvable filament is just HIPS, and using limolene to dissolve it, is not very pleasant at all. Your hands and house will smell like oranges for days. I rather use PLA as the support material with a heated ultrasonic tank and caustic soda. Both have safety concerns.
amd-tec
Post by amd-tec » Tue Oct 01, 2013 7:46 pm
wackojacko wrote:This dissolvable filament is just HIPS, and using limolene to dissolve it, is not very pleasant at all. Your hands and house will smell like oranges for days. I rather use PLA as the support material with a heated ultrasonic tank and caustic soda. Both have safety concerns.
PVA with PLA and HIPS with ABS, right?
Post by JuliaDee » Tue Oct 01, 2013 7:53 pm
amd-tec wrote:
wackojacko wrote:PVA with PLA and HIPS with ABS, right?
Why couldn't PVA be used with ABS? It dissolves in plain old water and is the most "friendly" soluble support I know of, although maybe it has some drawbacks I'm not aware of (it's extremely hygroscopic, naturally, of course).
As bruce mentioned, HIPS needs limonene and PLA needs lye (caustic) & ultrasonic.
amd-tec
Post by amd-tec » Tue Oct 01, 2013 8:46 pm
Sure if it works?
Would really like to see some studies from different soluble support materials, problem seems to be there are not many.
Post by JuliaDee » Wed Oct 02, 2013 1:20 pm
Post by wilsonj » Wed Oct 02, 2013 9:00 pm
I find ABS doesn't like to stick to PVA very well. That was the biggest issue I had. At this point PLA and ABS are a better option. IMO
